I will copy the log here. It is Kubuntu 16.04 with Letsencyot right from the repos.
2017-05-09 19:55:51,261:DEBUG:certbot.main:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.12.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 896, in main
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 692, in certonly
lineage = _get_and_save_cert(le_client, config, domains, certname, lineage)
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 87, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File “/usr/lib/python2.7/dist-packages/certbot/renewal.py”, line 296, in renew_cert
new_certr, new_chain, new_key, _ = le_client.obtain_certificate(domains)
File “/usr/lib/python2.7/dist-packages/certbot/client.py”, line 265, in obtain_certificate
self.config.allow_subset_of_names)
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 77, in get_authorizations
self._respond(resp, best_effort)
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 130, in _respond
resp, chall_update)
File “/usr/lib/python2.7/dist-packages/certbot/auth_handler.py”, line 154, in _send_responses
self.acme.answer_challenge(achall.challb, resp)
File “/usr/lib/python2.7/dist-packages/acme/client.py”, line 245, in answer_challenge
response = self.net.post(challb.uri, response)
File “/usr/lib/python2.7/dist-packages/acme/client.py”, line 686, in post
return self._post_once(*args, **kwargs)
File “/usr/lib/python2.7/dist-packages/acme/client.py”, line 697, in _post_once
response = self._send_request(‘POST’, url, data=data, **kwargs)
File “/usr/lib/python2.7/dist-packages/acme/client.py”, line 631, in _send_request
response = self.session.request(method, url, *args, **kwargs)
File “/usr/lib/python2.7/dist-packages/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python2.7/dist-packages/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python2.7/dist-packages/requests/adapters.py”, line 499, in send
raise ReadTimeout(e, request=request)
ReadTimeout: HTTPSConnectionPool(host=‘acme-v01.api.letsencrypt.org’, port=443): Read timed out. (read timeout=45)
I will try it from 12.04 again.
Regards,
Jan
