Certbot http challenge problem, maybe VPN issue?
I’ve been using certbot for many years on my home server that hosts a few domains and runs an email server. I cannot get a static IP directly through my internet provider, so I have a static IP VPN set up on this server for that purpose.
About 6 months ago the certbot automatic renewal failed. I tried renewing manually but it failed the http challenges. I’ve shown the result below for the hostname jezzubu.kehoe.org, which is the FQDN of the server and has a generic apache site on it (the actual websites are on virtual hosts). I have checked jezzubu.kehoe.org on https://letsdebug.net and it said all was OK. I followed the apache access logs and saw one successful retrieval of the /.well-known/acme-challenge/… file when I run the certbot command. How many retrievals should I expect?
I’m wondering if the IP address I have from my VPN provider has been tagged as Chinese/VPN and being blocked from one of the Letsencrypt challenge servers. The VPN endpoint is in Phoenix, AZ, but sometimes when I open Google on a browser on a VM that shares that IP, the google login prompt is in Chinese (not always, it flips back and forth from English). I believe I’m the only one using this IP, but maybe a block of IP’s had been tagged, or maybe the private IP is not as private as advertised. Also, before this cert issue I started having an issue with incoming SMTP connections on port 25 being blocked through the VPN connection from some origins (not all origins); I had to set up a secondary MX on a cheap VPS to get around that.
Please help, I’m limping along with self-signed certificates but that’s causing all sorts of other issues.
My domain is: jezzubu.kehoe.org
I ran this command: sudo certbot --apache -d jezzubu.kehoe.org
Requesting a certificate for jezzubu.kehoe.org
Domain: jezzubu.kehoe.org
Type: connection
Detail: During secondary validation: 23.81.125.21: Fetching http://jezzubu.kehoe.org/.well-known/acme-challenge/RKxQrUaEPP9lrpL77t7hRkeyyNCXRsbme9rRck4lCPg: Timeout during connect (likely firewall problem)
My web server is (include version): Apache 2.4.52-1ubuntu
The operating system my web server runs on is (include version): Ubuntu 22.04.5 LTS
My hosting provider, if applicable, is: self-hosted
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 3.0.0
there will be five iirc 3 in main + two usa server and one in europe and asia
as your error says during secondary validation I'd guess its about geoblocking firewall I guess
For success five. You can succeed with 4 but if that is a pattern that points to a likely geographic firewall blocking certain worldwide regions. One may occasionally fail for comms reasons or what-not.
Are you blocking all requests from Amazon AWS origins?
Because the Let's Encrypt primary center makes the first request and is not in AWS. All the others are. The error says "Secondary" failure so is not a problem from the primary center. All the secondaries failing would account for you seeing only one log entry.
And, Let's Debug issues two kinds of tests. One from its own server which succeeds and which is not AWS. The other uses Let's Encrypt staging system but it only checks the primary center which we know succeeds from your Certbot message.
I can't reach that domain from my own AWS region on US East Coast.
So, AWS seems the common denominator (so far anyway).
Hmm, interesting. I'm not blocking anything on my end, but I'm wondering if AWS is refusing to connect to an IP tagged as being on a VPN. I ran certbot again and confirmed that only one retrieval is getting through, from a 23.178.x.x IP.
This could also explain the SMTP issue I was having earlier. Gmail was one of the services that wouldn't deliver to this VPN IP; don't know if they use AWS but maybe use a common filtering service. Is there any recourse for this other than using a different VPN? Unfortunately I bought two years of the service just before this stuff started happening. Could the VPN service be actually sharing my supposedly "private" IP or is it just guilty of being in a known block of VPN addresses?
Thanks for the help.
No. AWS is not blocking outbound traffic from a server in its environ.
Are you sure the VPN has no firewall blocks?
What was the IP address that came through? It is not a secret especially it that is the original requester IP.
You mention China. Is this behind the great wall of china firewall?
I'm not sure how to verify this, obviously some traffic is getting through on port 80. When I had the SMTP issue, I did contact the VPN support about it but that didn't lead to a fix. I suppose I could try again with these additional clues.
Varies slightly each time I run certbot, although always only one gets through each run. Here are a few IPs see in the logs from the 'Let's Encrypt validation server':
23.178.112.214
23.178.112.212
66.133.109.36
The Let's Debug query came from here:
65.21.146.168
< You mention China. Is this behind the great wall of china firewall?
I'm in Seattle, WA and the VPN endpoint is in Phoenix, AZ. I think the VPN provider serves a lot of customers in China, and I've seen evidence that my IP, or block of IP's including mine, has been somehow tagged as Chinese, for example when I browse the web using my Private IP, Google occasionally presents the Chinese login screen. The China Firewall may have tagged this IP as VPN and blocking it, but would that alone prevent certbot from running?
Thanks again for your help.
Actually, to clarify, it's the (annoying, IMHO) google login popup prompt in Firefox that's coming up in Chinese when I'm on my VPN IP. I'd post a screenshot but it's in English at the moment...
Those are IP of the primary Let's Encrypt center which is not AWS. The other is the Let's Debug test server as I described. None of the secondary LE centers which are in AWS are reaching you.
And, as noted, I cannot reach your "home" page from my own AWS EC2 test server. I can reach you from another test server I have just not the AWS one.
This isn't Let's Encrypt unique. You need to work with your VPN provider and find out why these are blocked. Maybe they had a problem with too many bots or something and block inbound requests from AWS IP. I don't know.
I can't reach your home page:
curl -i -m10 http://jezzubu.kehoe.org
curl: (28) Connection timed out after 10001 milliseconds
Thanks for the info and troubleshooting help, I really do appreciate it and this helps me make more-targeted and informed queries to my VPN provider.
I might consider ditching the VPN altogether and instead see if I can tunnel into the VPS to use its static IP
I don't understand exactly why you need the VPN. It didn't matter for this problem as HTTP requests must work and your comms config must allow it.
You said you needed the VPN to provide a 'static IP' so I wasn't sure if you had a public IP of your own (that just changed) or did not have a public IP at all. The former would just need a DDNS service but the latter something more (like a VPN).
Assuming the latter you might look at Cloudflare. There is a tunnel feature that allows connections when you don't have a public IP. Tunnel | Zero Trust App Connector
If you do have a public IP that just changes there are many DDNS services. Cloudflare describes options with their system here: Dynamically update DNS records | Cloudflare DNS docs
Update: After much back and forth with my VPN provider, they finally admitted that they have been blocking incoming connections from AWS "for customer's protection" and won't make an exception for my static IP. So mystery solved, but I'm not happy with this VPN provider and I'm currently working to wean myself off of it.
I don't have direct access to a public IP since my internet connection comes through a neighbor's router, so I'm behind NAT. I could go over there on occasion and set up port forwards, but I don't have real control over it, plus I think they've already claimed port 80 for their own use.
I looked into the Cloudflare tunnel, looks interesting although from reading the documentation it seems like it's geared towards web hosting, and I need the IP for a lot more than that (SMTP, running VM's, etc). Since I have the VPS set up already, I've set up a connection to it via wireguard and I'm currently working on getting routing and port forwarding set up so that I can ditch the VPN.
Thanks for the info!
Since inbound HTTP traffic is not possible another option is to use a DNS Challenge: Challenge Types - Let's Encrypt
