I recently had to rebuild my VPS after running a command that completely overwrote my software
. I decided to switch to using NGINX for my “new” server, after having used Apache for my old one. On my old server I had set up a Let’s Encrypt certificate with Certbot and that worked fine. Though, now it times out every time I try to get a certificate for the new server.
My domain is: ianmorrill.com
I ran this command: sudo certbot --nginx
tls-sni-01 challenge for ianmorrill.com
Failed authorization procedure. ianmorrill.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
Domain: ianmorrill.com
Type: connection
Detail: Timeout
My web server is (include version): Nginx 1.10.3
The operating system my web server runs on is (include version): Ubuntu 16.04
My hosting provider, if applicable, is: Linode
