I am just wondering if Certbot is a work in progress for CentOS 8? And if it is, is there an ETA?
Yes, the official instructions are to use certbot-auto: https://certbot.eff.org/lets-encrypt/centosrhel8-other
Thank you for the quick reply.
Now that will let me set my Apache cert but what about for my email server? I am using postfix and dovecot for my email server. Is it done the same way? or do I just use the same cert? In the past I just created one for Apache and then one for my email using www.example.com for apache and mail.example.com for my email.
Assuming mail.example.com
is on the same server as www.example.com
, you could create a dummy virtualhost in Apache that responds to mail.example.com
<VirtualHost *:80>
ServerName mail.example.com
</VirtualHost>
and issue a separate certificate for it:
certbot certonly -d mail.example.com -a apache \
--deploy-hook "service postfix reload; service dovecot reload"
Certbot doesn’t know how to configure Postfix and Dovecot with the new certificate, so you’ll need to do that part on your own. https://ssl-config.mozilla.org can propose configuration for both Postfix and Dovecot.
Just substitute the file paths:
Mozilla SSL Config Path | Certbot Path |
/path/to/signed_cert_plus_intermediates |
/etc/letsencrypt/live/mail.example.com/fullchain.pem |
/path/to/private_key |
/etc/letsencrypt/live/mail.example.com/privkey.pem |
Why do these two services want different verbs here? I suppose the dovecot
service as packaged by the operating system lacks a concept of reloading?
I couldn’t find a quick answer to whether Dovecot reloads the certificate by SIGHUP or not. I’ve tested now - it does.
I will not be needing a VirtualHost for the email server. The mail.example.com will be used strictly for the email server. As for the www.example.com will be strictly for when I set up web mail.
@schoen Unfortunately when I set up CentOS 8 on my system I did a minimal install, which did not include Dovecot, so I had to install Dovecot after setting up the OS.
The purpose of the virtualhost is so that you can acquire a certificate for that domain using HTTP validation.
Otherwise, you don't have a way to authenticate your control of mail.example.com
Okay now I understand. I will just add that line to my already existing VirtualHost.
