Certbot errors, i got these errors and nothing seems to work?
My domain is:mrsloth.xyz
I ran this command: certbot --apache
the error i got as follows:
Please enter the domain name(s) you would like on your certificate (comma and/or
space separated) (Enter 'c' to cancel): mrsloth.xyz
Requesting a certificate for mrsloth.xyz
Domain: mrsloth.xyz
Type: dns
Detail: DNS problem: looking up A for mrsloth.xyz: DNSSEC: DNSKEY Missing; DNS problem: looking up AAAA for mrsloth.xyz: DNSSEC: DNSKEY Missing
here is my error log;
2023-10-10 14:49:26,717:DEBUG:certbot._internal.main:certbot version: 2.1.0
2023-10-10 14:49:26,717:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2023-10-10 14:49:26,717:DEBUG:certbot._internal.main:Arguments: ['-d', 'christmas.mrsloth.xyz']
2023-10-10 14:49:26,717:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#stan>
2023-10-10 14:49:26,725:DEBUG:certbot._internal.log:Root logging level set at 30
2023-10-10 14:49:26,726:DEBUG:certbot._internal.plugins.selection:Requested authenticator None and installer None
2023-10-10 14:49:26,726:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2023-10-10 14:49:49,994:DEBUG:certbot._internal.main:certbot version: 2.1.0
2023-10-10 14:49:49,994:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2023-10-10 14:49:49,994:DEBUG:certbot._internal.main:Arguments: ['-d', 'christmas.mrsloth.xyz']
2023-10-10 14:49:49,994:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#stan>
2023-10-10 14:49:50,005:DEBUG:certbot._internal.log:Root logging level set at 30
2023-10-10 14:49:50,007:DEBUG:certbot._internal.plugins.selection:Requested authenticator None and installer None
2023-10-10 14:49:50,007:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2023-10-10 14:51:18,574:DEBUG:certbot._internal.main:certbot version: 2.1.0
2023-10-10 14:51:18,574:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2023-10-10 14:51:18,574:DEBUG:certbot._internal.main:Arguments:
2023-10-10 14:51:18,574:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#stan>
2023-10-10 14:51:18,581:DEBUG:certbot._internal.log:Root logging level set at 30
2023-10-10 14:51:18,582:DEBUG:certbot._internal.plugins.selection:Requested authenticator None and installer None
2023-10-10 14:51:18,582:DEBUG:certbot._internal.plugins.selection:No candidate plugin
2023-10-10 14:51:37,367:DEBUG:certbot._internal.main:certbot version: 2.1.0
2023-10-10 14:51:37,368:DEBUG:certbot._internal.main:Location of certbot entry point: /usr/bin/certbot
2023-10-10 14:51:37,368:DEBUG:certbot._internal.main:Arguments:
2023-10-10 14:51:37,368:DEBUG:certbot._internal.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#stan>
2023-10-10 14:51:37,375:DEBUG:certbot._internal.log:Root logging level set at 30
You need to get your domain name working before you'll be able to get a certificate for it. (And before any users will be able to reliably use it, really.) Your registrar has configured the domain name to use DNSSEC, but your DNS Servers isn't configured to sign the responses. You need to either remove DNSSEC, or preferably actually set it up. But right now, no DNSSEC-checking resolver is able to use your domain name.
You can see your DNSSEC issue graphically using e.g. DNSViz:
https://dnsviz.net/d/mrsloth.xyz/dnssec/
That's brilliant information thanks so much Peter I've now got I good idea how I can solve the issue
Many thanks
