Example in the folder that contains the certificate:
cert1.pem
cert2.pem
cert3.pem
certn.pem
i just want to make always same name as:
cert1.pem or cert.pem
and override automatically
is it possible?
Note: add more itens when renew the certificate
No, Certbot doesn’t have a setting to do that.
Why do you ask?
You should use the symlinks such as /etc/letsencrypt/live/example.com/cert.pem rather than directly using stuff in /etc/letsencrypt/archive/.
Pointing my route to symlinks does not work. The certificate does not load. Im using Windowns 10 because a delphi datasnap application.
schoen
4
That is weird but I don’t know enough about Windows to know where to place the blame.
Perhaps you could use a --deploy-hook script to create a copy of the current symlink contents at a fixed location.
system
Closed
5
