My domain is: newtrail.galaxyproject.org
I ran this command: /opt/certbot/bin/certbot certonly --test-cert --non-interactive --dns-rfc2136 --dns-rfc2136-credentials /etc/letsencrypt/dns-rfc2136-credentials.ini --register-unsafely-without-email --agree-tos -d newtrail.galaxyproject.org
Plugins selected: Authenticator dns-rfc2136, Installer None
dns-01 challenge for newtrail.galaxyproject.org
Encountered exception during recovery:
File "/opt/certbot/local/lib/python2.7/site-packages/certbot/error_handler.py", line 124, in _call_registered
self.funcs[-1]()
File "/opt/certbot/local/lib/python2.7/site-packages/certbot/auth_handler.py", line 243, in _cleanup_challenges
self.auth.cleanup(achalls)
File "/opt/certbot/local/lib/python2.7/site-packages/certbot/plugins/dns_common.py", line 77, in cleanup
self._cleanup(domain, validation_domain_name, validation)
File "/opt/certbot/local/lib/python2.7/site-packages/certbot_dns_rfc2136/dns_rfc2136.py", line 79, in _cleanup
self._get_rfc2136_client().del_txt_record(validation_name, validation)
File "/opt/certbot/local/lib/python2.7/site-packages/certbot_dns_rfc2136/dns_rfc2136.py", line 163, in del_txt_record
.format(e))
PluginError: Encountered error deleting TXT record: The peer didn't know the key we used
Encountered error adding TXT record: The peer didn't know the key we used
nginx version: nginx/1.14.0 (Ubuntu)
built with OpenSSL 1.1.1 11 Sep 2018
TLS SNI support enabled
The operating system my web server runs on is (include version): Ubuntu 18.04.3 LTS
My hosting provider, if applicable, is: AWS EC2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.40.1
Running BIND 9.11.3, the relevant configuration sections (the key is not my real key) are:
key "certbot." {
algorithm hmac-sha512;
secret "4N9qH7FfZxGpxPo6iIFraJAT2kwcaqF2S2ClxmhT3iKw85NGSUTTdfM6bWWa1qMGIjqCD/G+9gq6KW/aZvaZ4g==";
acl "galaxy" {
10.0.0.0/8;
127.0.0.1/32;
::1/128;
options {
directory "/var/cache/bind";
dnssec-validation auto;
auth-nxdomain no;
listen-on-v6 {
any;
listen-on {
any;
notify explicit;
recursion no;
allow-recursion {
none;
allow-transfer {
key axfr-galaxy.;
key axfr-global.;
allow-query {
any;
query-source address * port *;
max-ncache-ttl 3600;
lame-ttl 86400;
cleaning-interval 120;
view "galaxy" {
match-clients {
!key certbot.;
!key axfr-global.;
key axfr-galaxy.;
galaxy;
recursion yes;
allow-recursion { any; };
also-notify {
3.136.94.7 key axfr-galaxy.;
128.118.250.8 key axfr-galaxy.;
/* includes */
include "/etc/bind/named.conf.default-zones";
/* zones */
zone "galaxyproject.org" IN {
type master;
file "/etc/bind/zones/galaxyproject.org.private.zone";
view "global" {
match-clients {
key certbot.;
!key axfr-galaxy.;
key axfr-global.;
!galaxy;
any;
recursion no;
allow-recursion { none; };
also-notify {
3.136.94.7 key axfr-global.;
128.118.250.8 key axfr-global.;
/* zones */
type master;
file "/etc/bind/zones/galaxyproject.org.zone";
update-policy {
grant certbot. zonesub TXT;
The certbot credentials file contains:
dns_rfc2136_name = certbot.
dns_rfc2136_secret = 4N9qH7FfZxGpxPo6iIFraJAT2kwcaqF2S2ClxmhT3iKw85NGSUTTdfM6bWWa1qMGIjqCD/G+9gq6KW/aZvaZ4g==
dns_rfc2136_port = 53
dns_rfc2136_algorithm = hmac-sha512
dns_rfc2136_server = 3.14.178.173
BIND logs:
11-Dec-2019 14:57:51.981 debug 2: tsig key 'certbot': unknown key
11-Dec-2019 14:57:51.982 error: client @0x7f1a580d5a50 3.14.178.173#48752: view galaxy: request has invalid signature: TSIG certbot: tsig verify failure (BADKEY)
The relevant bit there is view galaxy: this request should match the global view, but it does not. I am not sure where key 'certbot' comes from, but if I rename the key to certbot (without the trailing period) in all places, I get the same error. Using the same key with BIND’s nsupdate works (or would if not for an unrelated filesystem permission issue that I’ll fix, but certbot doesn’t get this far):
# cat certbot.key
key "certbot." {
# cat ddns-test.txt
server 3.14.178.173 53
debug
zone galaxyproject.org
update add _acme-challenge.newtrail.galaxyproject.org. 180 TXT "ddns-test"
show
send
# nsupdate -k certbot.key ddns-test.txt
Outgoing update query:
;; ->>HEADER<<- opcode: UPDATE, status: NOERROR, id: 0
;; flags:; ZONE: 0, PREREQ: 0, UPDATE: 0, ADDITIONAL: 0
;; ZONE SECTION:
;galaxyproject.org. IN SOA
;; UPDATE SECTION:
_acme-challenge.newtrail.galaxyproject.org. 180 IN TXT "ddns-test"
Sending update to 3.14.178.173#53
;; ->>HEADER<<- opcode: UPDATE, status: NOERROR, id: 59627
;; flags:; ZONE: 1, PREREQ: 0, UPDATE: 1, ADDITIONAL: 1
;; ZONE SECTION:
;; UPDATE SECTION:
;; TSIG PSEUDOSECTION:
certbot. 0 ANY TSIG hmac-sha512. 1576077745 300 64 FOO BAR== 59627 NOERROR 0
Reply from update query:
;; ->>HEADER<<- opcode: UPDATE, status: SERVFAIL, id: 59627
;; flags: qr; ZONE: 1, PREREQ: 0, UPDATE: 0, ADDITIONAL: 1
;; ZONE SECTION:
certbot. 0 ANY TSIG hmac-sha512. 1576077745 300 64 BAZ QUUX== 59627 NOERROR 0
BIND in this case logs:
11-Dec-2019 15:22:25.134 info: client @0x7f1a580c72c0 3.14.178.173#18699/key certbot: view global: updating zone 'galaxyproject.org/IN': adding an RR at '_acme-challenge.newtrail.galaxyproject.org' TXT "ddns-test"
11-Dec-2019 15:22:25.135 debug 1: journal file /etc/bind/zones/galaxyproject.org.zone.jnl does not exist, creating it
11-Dec-2019 15:22:25.135 error: /etc/bind/zones/galaxyproject.org.zone.jnl: create: permission denied
11-Dec-2019 15:22:25.135 info: client @0x7f1a580c72c0 3.14.178.173#18699/key certbot: view global: updating zone 'galaxyproject.org/IN': error: journal open failed: unexpected error
11-Dec-2019 15:22:25.135 debug 1: delete_node(): 0x7f1a5eefe210 _acme-challenge.newtrail.galaxyproject.org (bucket 6)
Here it’s landed in the right view. So it looks like nsupdate is doing something different in regards to how the key is sent. I haven’t dug in to the packets or DNSSEC spec yet to figure out what the difference is, but it looks like Certbot is missing something here?
