You probably just forgot to copy/link one of the files.
Or maybe that chmod command that messes with certbot.
In /etc/ssl/private/*** initially were files: cert.pem, chain.pem, fullchain.pem, fullchain.srt, privkey.pem, privkey.key after certbot installation they are static links to
\etc\letsencrypt\live\ (cert.pem, chain.pem, fullchain.pem and privkey.pem) renewed by certbot, so they are point to \etc\letsencrypt\archive*** (certNN.pem, chainNN.pem, fullchainNN.pem and privkeyNN.pem) - real key files formed by certbot
Some links go in /etc/ssl/certs, according to that document.
Actually it is confusing. Installation was not done by me, but I installed certificates initially by hands instead of old ones. The working certificates was definitely in /etc/ssl/private/***, not "
ssl_certificate /etc/ssl/certs/iRedMail.crt;
ssl_certificate_key /etc/ssl/private/iRedMail.key "
I don't know what to tell you. Moreover, your dovecot is presenting the correct certificate with the proper chain.
Something happened that made postfix behave differently.
Now it is with cert.pem with manually copied second certificate.
It looks like it works
❯ echo "" | openssl s_client -connect mail.protorg.msk.ru:25 -starttls smtp
CONNECTED(00000003)
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = mail.protorg.msk.ru
verify return:1
Certificate chain
0 s:CN = mail.protorg.msk.ru
a:PKEY: id-ecPublicKey, 256 (bit); sigalg: RSA-SHA256
v:NotBefore: Jul 10 19:07:13 2023 GMT; NotAfter: Oct 8 19:07:12 2023 GMT
a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
v:NotBefore: Sep 4 00:00:00 2020 GMT; NotAfter: Sep 15 16:00:00 2025 GMT
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=CN = mail.protorg.msk.ru
issuer=C = US, O = Let's Encrypt, CN = R3
Peer signing digest: SHA256
Peer signature type: ECDSA
Server Temp Key: X25519, 253 bits
SSL handshake has read 3018 bytes and written 434 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 256 bit
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
250 CHUNKING
DONE
~ took 6s
That sounds unnecessary OR hard to automate.
What is the automated solution?
This is exactly my question! How to automate it and why it behaves like this.
Well, the topic title is a given.
If the fullchain.pem fails and the cert.pem+"second certificate" works...
Then you may need to request a cert with the short chain and use that fullchain.pem file.
OR
Request a cert from some other free CA.
