Certbot commands help?
infiniteblocks.net
Tried CentOS6 and 7 commands, I’m using putty for ssh access
I followed this tutorial https://certbot.eff.org/lets-encrypt/centos6-apache
I tried many variations of the commands. The first two commands:
wget https://dl.eff.org/certbot-auto
chmod a+x certbot-auto
Worked fine, however the other commands came up with:
-bash: ./path/to/certbot-auto: No such file or directory
And i tried listing paths, i tried variations of most of the commands because i don’t know linux very well.
Apache
centos - but i don’t know the version that’s the problem
siteground
i can access ssh/shell access
cpanel
Hi @jakeroy
if you use cpanel,
you should check if there is an integrated cPanel-Support. There is a Letsencrypt-Plugin which is the best option.
The Let's Encrypt Plugin
Certbot:
./path/to/certbot-auto doesn't mean to type in ./path/to/certbot-auto, but rather to provide the directory path where you've downloaded certbot-auto. If you ran the wget command from your home directory, this is usually just . (the current working directory), hence ./certbot-auto. Unlike Windows systems, Unix normally doesn't let you run commands from your current working directory just by typing the name of the command, without explicitly saying that this is the command you want to run.
@JuergenAuer's suggestion to prefer the builtin cPanel support over Certbot if you normally administer the site via cPanel is good advice.
