I got the certbot certificate succesfully however it still shows as not secure.
I did a scan on www.whynopadlock.com and all is good except it says invalid intermediate, i dont know how to fix this error if this even is this cause of the not secure message I don't really know.
I'm setting up a gophish server as part of a pentesting course I'm taking any help would be much appreciated.
You keep removing questions from the questionnaire. Please don't do that. Something has gone wrong with installing the certificate so I really like to see the Certbot command you've used and its exact output:
(Also, Ubuntu is not a webserver software, but a Linux distribution a.k.a. OS.)
I doubt that. Your webserver is still serving just the end leaf certificate without the intermediate certificate(s). Re-running the Certbot command wouldn't have changed anything. You probably forced a renewal unnecessarily, so you now have two certificates issued: crt.sh | facebook-authenticate.ml The first one was perfectly fine already, so the only thing you've managed is adding extra load on the Let's Encrypt systems unnecessarily.
As you've used the certonly subcommand, you must have installed the certificate manually. When doing so, you probably have used cert.pem instead of fullchain.pem, thus missing the intermediate(s).
Also, I'm curious why you're using the standalone authenticator? That's usually not the best option. Although as you have not specified which webserver you're using I can't make any recommendation.
