My domain is: rycoh.net
I ran this command: sudo certbot --nginx -d rycoh.net
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): Ubuntu 20.04.5 LTS
My hosting provider, if applicable, is: Space Hosting
or certbot-auto --version
if you're using Certbot): certbot 0.40.0
Hello, whenever I try to run the command to run certbot, it always says "Timeout during connect (likely firewall problem)", port 80 and 443 are both accessible, and firewall is fully disabled until I fix this issue, running certbot with this command line: sudo certbot certonly --nginx -d rycoh.net --dry-run --debug-challenges -v
parameters, works, until I actually press enter to continue ("submit to CA"), after that the website stops working and if I try to access it from my browser it returns "ERR_CONNECTION_REFUSED".
I'm not really sure if I'm doing something wrong myself or something is broken, I've been trying to fix it for the past hours, and I haven't gotten anything and didn't found anyone with the same issue either. If you need some logs let me know and I will upload them. Thank you!
