I don’t think your explanation makes sense here. All four names mobiledatabook.net, www.mobiledatabook.net, mobiledatabooks.net, and www.mobiledatabooks.net are currently pointing at the same server, 98.190.6.20 or 2001:57a:ef00::24.
Both domains are pointed at the same server right now, so the existence of the other server wouldn’t be the reason that your certificate renewal fails.
