My domain is: systematicpoliticalscience.com
I ran this command: certbot-auto
requested (ref: /etc/letsencrypt/renewal/systematicpoliticalscience.com.conf)
It contains these names: systematicpoliticalscience.com,
www.systematicpoliticalscience.com
You requested these names for the new certificate:
systematicpoliticalscience.org, systematicpoliticalscience.com,
new.systematicpoliticalscience.com, old.systematicpoliticalscience.com,
www.systematicpoliticalscience.org, www.systematicpoliticalscience.com.
certificate?
(E)xpand/©ancel: e
http-01 challenge for new.systematicpoliticalscience.com
http-01 challenge for old.systematicpoliticalscience.com
http-01 challenge for systematicpoliticalscience.com
http-01 challenge for systematicpoliticalscience.org
http-01 challenge for www.systematicpoliticalscience.com
http-01 challenge for www.systematicpoliticalscience.org
Waiting for verification…
Challenge failed for domain old.systematicpoliticalscience.com
Challenge failed for domain new.systematicpoliticalscience.com
Domain: new.systematicpoliticalscience.com
Type: connection
Detail: Fetching
http://new.systematicpoliticalscience.com/.well-known/acme-challenge/38N3tJuwiV1HlgBHARqJiC6z9Ig3MfkiMcBYRqp2yZo:
Timeout during connect (likely firewall problem)To fix these errors, please make sure that your domain name was
that you are serving files from the webroot path you provided. -
Domain: old.systematicpoliticalscience.com
Detail: Invalid response from
http://old.systematicpoliticalscience.com/.well-known/acme-challenge/7CdMwokEVQkpEnyXf1ratQDNkhpk63ht0IVNtP7sEfM
[24.15.80.74]: “\n\n300 Multiple
Choices\n\nMultiple C”
Apache
Server version: Apache/2.4.10 (Debian)
Server built: Sep 30 2019 19:32:08
Debian / Jesse
Linode
Yes
No
or certbot-auto --version
if you’re using Certbot):
certbot 1.4.0
I received a complaint today that systematicpoliticalscience.com is giving an error. It appears to have an expired certificate. This time, running certbot-auto a few different ways did not result in a new certificate being installed; https://systematicpoliticalscience.com is still reporting an expired certificate.
What should I be doing differently so that a fresh new certificate is served up from systematicpoliticalscience.com?
