Certbot-auto fails while setting up virtual environment, complains about package hashes
Dudes, this helps:
diff --git a/letsencrypt-auto b/letsencrypt-auto
index 80f39cf..6ebadb1 100755
--- a/letsencrypt-auto
+++ b/letsencrypt-auto
@@ -574,8 +574,6 @@ argparse==1.4.0 \
 # This comes before cffi because cffi will otherwise install an unchecked
 # version via setup_requires.
-pycparser==2.14 \
-    --hash=sha256:7959b4a74abdc27b312fed1c21e6caf9309ce0b29ea86b591fd2e99ecdf27f73
 cffi==1.4.2 \
     --hash=sha256:53c1c9ddb30431513eb7f3cdef0a3e06b0f1252188aaa7744af0f5a4cd45dbaf \
@@ -912,6 +910,8 @@ UNLIKELY_EOF
     # Set PATH so pipstrap upgrades the right (v)env:
     PATH="$VENV_BIN:$PATH" "$VENV_BIN/python" "$TEMP_DIR/pipstrap.py"
     set +e
+    #XXX
+    $VENV_BIN/pip install git+https://github.com/eliben/pycparser@release_v2.14
     PIP_OUT=`"$VENV_BIN/pip" install --no-cache-dir --require-hashes -r "$TEMP_DIR/letsencrypt-auto-requirements.txt" 2>&1`
     PIP_STATUS=$?
     set -e
As a tmp solution, of course.
Thanks, murchik. It works.
I am so sorry I had a copy paste fail.
What is meant to write was
pip install pycparser==2.13
I downgraded my pycparser to 2.13 and then I could install cryptography fine
pip install cryptography
Adding “–no-binary pycparser” as recommended in the pycparser git issue tracker worked for me on a Raspberry Pi with Raspbian Jessie:
Change certbot-auto as follows:
diff --git a/certbot-auto b/certbot-auto
index 80f39cf..aba3a28 100755
--- a/certbot-auto
+++ b/certbot-auto
@@ -575,7 +575,8 @@ argparse==1.4.0 \
 pycparser==2.14 \
+    --hash=sha256:7959b4a74abdc27b312fed1c21e6caf9309ce0b29ea86b591fd2e99ecdf27f73 \
+    --no-binary pycparser
 cffi==1.4.2 \
I confirm @seadog 's fix works on Ubuntu 14.04 LTS aswell.
I confirm @seadog fix too, worked on Ubuntu 14.04. Thanks!
Even i am facing the same issue . in ubuntu 14.04,
I also confirm that @seadog 's fix works on Ubuntu 14.04 LTS. You have to modify your certbot-auto script and add that one line after --hash=sha256... like so:
pyparser==2.14 \ --hash=sha256:7959b4a74abdc27b312fed1c21e6caf9309ce0b29ea86b591fd2e99ecdf27f73 \ --no-binary pycparser
instead of:
Hey! @pfzero
please let me how edit that file in ubuntu…
i confirm @seadog fix too, it worked on Ubuntu 14.04,
sudo nano certbot-auto search for : pycparser==2.14 in the file
add --no-binary pycparser
below --hash=sha256:7959b4a74abdc27b312fed1c21e6caf9309ce0b29ea86b591fd2e99ecdf27f73 \
save the file and execute it
Thanks!
Issue has been resolved :slight_smile:
Phew. @nickschwab is correct that this issue has been resolved. For those that are curious, I wrote up a bit of a postmortem about what happened on our GitHub repo:
Nicely done Sir!
Thank you very much
Mike
