Certbot-auto failed to complete - Had a problem while installing Python packages
I have followed the instruction here How to integrate free SSL certificate into AWS instance with Let’s Encrypt | by Tarikul Islam | Oceanize Lab Geeks | Medium, successfully, on several occasions. Today, I ran into a problem – certbot-auto failed to install, details follow.
My domain is: pairofdocs.net
I ran this command: sudo ./certbot-auto --debug -v --server https://acme-v01.api.letsencrypt.org/directory certonly --webroot -w /var/www/html -d pairofdocs.net -d www.pairofdocs.net.
My web server is (include version): Apache/2.4.37 (Amazon)
The operating system my web server runs on is (include version): Amazon Linux AMI release 2018.03
My hosting provider, if applicable, is: Amazon AWS
I'm using a control panel to manage my site: no
The version of my client is (e.g. output of certbot-auto --version):
FATAL: Amazon Linux support is very experimental at present... if you would like to work on improving it, please ensure you have backups and then run this script again with the --debug flag! Alternatively, you can install OS dependencies yourself and run this script again with --no-bootstrap. [NOTE: The --no-bootstrap did not resolve the issue.]
Other notes:
  • There was a ‘traditional’ SSL certificate previously installed on this server that recently expired.
  • The PATH variable is /usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/opt/aws/bin:/home/ec2-user/.local/bin:/home/ec2-user/bin and python is located in /usr/bin
  • After the failure, I did a ls –R /opt/eff-org and found nothing other than the certbot folder.
It produced this output (I had to remove most of the output because this BBS is telling me that I can only post 20 links):
Bootstrapping dependencies for Amazon... (you can skip this with --no-bootstrap)
yum is /usr/bin/yum
yum is hashed (/usr/bin/yum)
Loaded plugins: priorities, update-motd, upgrade-helper
amzn-main | 2.1 kB 00:00:00
amzn-updates | 2.5 kB 00:00:00
Package gcc-4.8.5-1.22.amzn1.noarch already installed and latest version
Package augeas-libs-1.0.0-5.7.amzn1.x86_64 already installed and latest version
Package 1:openssl-1.0.2k-16.146.amzn1.x86_64 already installed and latest version
Package 1:openssl-devel-1.0.2k-16.146.amzn1.x86_64 already installed and latest version
Package libffi-devel-3.0.13-16.5.amzn1.x86_64 already installed and latest version
Package system-rpm-config-9.0.3-42.28.amzn1.noarch already installed and latest version
Package ca-certificates-2017.2.14-65.0.1.17.amzn1.noarch already installed and latest version
Package python27-devel-2.7.15-1.124.amzn1.x86_64 already installed and latest version
Package python27-virtualenv-15.1.0-1.14.amzn1.noarch already installed and latest version
Package python27-tools-2.7.15-1.124.amzn1.x86_64 already installed and latest version
Package python27-pip-9.0.3-1.26.amzn1.noarch already installed and latest version
Nothing to do
Creating virtual environment...
Already using interpreter /usr/bin/python2.7
New python executable in /opt/eff.org/certbot/venv/bin/python2.7
Also creating executable in /opt/eff.org/certbot/venv/bin/python
Installing setuptools, pip, wheel...done.
Installing Python packages...
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
Collecting argparse==1.4.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 11))
Downloading https://files.pythonhosted.org/packages/f2/94/3af39d34be01a24a6e65433d19e107099374224905f1e0cc6bbe1fd22a2f/argparse-1.4.0-py2.py3-none-any.whl
[various downloads and installs not reported]
Collecting zope.component==4.2.2 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 161))
Downloading https://files.pythonhosted.org/packages/4c/c4/3f77127c876f49af478e8ea4dc223cda17730bb273c0d1606a4114c64008/zope.component-4.2.2.tar.gz (546kB)
100% |████████████████████████████████| 552kB 50.6MB/s
Collecting zope.event==4.1.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 164))
Downloading https://files.pythonhosted.org/packages/0e/87/75e3d62a3506953c2e56d15a150de31e5d92310e87db2c8b102dc01b0b8e/zope.event-4.1.0.tar.gz (476kB)
100% |████████████████████████████████| 481kB 49.5MB/s
Collecting zope.interface==4.1.3 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 167))
Downloading https://files.pythonhosted.org/packages/9d/81/2509ca3c6f59080123c1a8a97125eb48414022618cec0e64eb1313727bfe/zope.interface-4.1.3.tar.gz (141kB)
100% |████████████████████████████████| 143kB 49.0MB/s
Collecting requests-toolbelt==0.8.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 185))
Downloading https://files.pythonhosted.org/packages/97/8a/d710f792d6f6ecc089c5e55b66e66c3f2f35516a1ede5a8f54c13350ffb0/requests_toolbelt-0.8.0-py2.py3-none-any.whl (54kB)
100% |████████████████████████████████| 61kB 43.0MB/s
Collecting chardet==3.0.2 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 188))
Downloading https://files.pythonhosted.org/packages/b8/74/54fdc2fcfdd46b6c486964b64c5bb7db9a3664033ab25cf11aab06dd2a5d/chardet-3.0.2-py2.py3-none-any.whl (133kB)
Collecting urllib3==1.24.1 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 191))
Downloading https://files.pythonhosted.org/packages/62/00/ee1d7de624db8ba7090d1226aebefab96a2c71cd5cfa7629d6ad3f61b79e/urllib3-1.24.1-py2.py3-none-any.whl (118kB)
100% |████████████████████████████████| 122kB 50.0MB/s
Collecting certifi==2017.4.17 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 194))
Downloading https://files.pythonhosted.org/packages/eb/01/c1f58987b777d6c4ec535b4e004a4a07bfc9db06f0c7533367ca6da8f2a6/certifi-2017.4.17-py2.py3-none-any.whl (375kB)
100% |████████████████████████████████| 378kB 49.9MB/s
Collecting letsencrypt==0.7.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 205))
Downloading https://files.pythonhosted.org/packages/fd/21/0c6f33829fadec8aca0c1ebb4d6f8101c05899356a58d1b2e506cb77cf18/letsencrypt-0.7.0-py2-none-any.whl
Collecting certbot==0.30.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 209))
Downloading https://files.pythonhosted.org/packages/e0/5e/9881564f386c1294d6cf387d5c754d7eb3277507b46afac1c646d6ae6de6/certbot-0.30.0-py2.py3-none-any.whl (317kB)
100% |████████████████████████████████| 327kB 50.4MB/s
Collecting acme==0.30.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 212))
Downloading https://files.pythonhosted.org/packages/df/a7/fc6114c715233ab53c9571d3b710d596bc80446eac14e0906362fa69e4b1/acme-0.30.0-py2.py3-none-any.whl (85kB)
100% |████████████████████████████████| 92kB 44.2MB/s
Collecting certbot-apache==0.30.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 215))
Downloading https://files.pythonhosted.org/packages/37/37/46433ff4358e12d1caf4101308411bf1dad0df3e27e2e62c5037ca75d2e0/certbot_apache-0.30.0-py2.py3-none-any.whl (228kB)
100% |████████████████████████████████| 235kB 50.7MB/s
Collecting certbot-nginx==0.30.0 (from -r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 218))
Downloading https://files.pythonhosted.org/packages/ad/15/7f42f31ba068f837816647135a0704a8c89aad685df160407e92870c0277/certbot_nginx-0.30.0-py2.py3-none-any.whl (90kB)
100% |████████████████████████████████| 92kB 44.0MB/s
Requirement already satisfied: setuptools>=1.0 in /opt/eff.org/certbot/venv/lib/python2.7/site-packages (from josepy==1.1.0->-r /tmp/tmp.U39lxIK4BG/letsencrypt-auto-requirements.txt (line 95)) (40.6.3)
Exception:
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line 176, in main
status = self.run(options, args)
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 346, in run
session=session, autobuilding=True
File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 848, in build
assert building_is_possible
AssertionError
Had a problem while installing Python packages.
I believe this may be related a known issue: Certbot has problem setting up the virtual environment
In the interim, you might be able to use by adding:
--no-self-upgrade
[Try that and post here either way.]
I have exactly the same problem, using --no-self-upgrade do not resolve the problems.
Seems to be due to deprecated Python 2.7
I can confirm the same error with a fresh Ubuntu 16.04.5 LTS install on aws.
I don’t think --no-self-upgrade is going to work for me since I’ve never issued that first cert on this server.
Anxiously awaiting any suggestions.
Thanks!
As suggested by the previous two respondents, --no-self-upgrade did not resolve the issue.
This was fixed a couple hours ago. Can you try running certbot-auto again? Does it work now? Do you get a different error?
I just reran the process from the top, starting with downloading certbot-auto using
wget https://dl.eff.org/certbot-auto
After this, I received the exact same error.
Based on wasah64’s comment, I installed Python 3.6 but cerbot-auto is still calling Python 2.7. I did some searching and could not find a way to force it to use the newer version of Python.
I am also seeing this on ubuntu 18.04, fresh install on Digital Ocean.
Collecting argparse==1.4.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 11))
Collecting pycparser==2.14 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 17))
  Downloading https://files.pythonhosted.org/packages/6d/31/666614af3db0acf377876d48688c5d334b6e493b96d21aa7d332169bee50/pycparser-2.14.tar.gz (223kB)
Collecting asn1crypto==0.22.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 21))
  Downloading https://files.pythonhosted.org/packages/97/ba/7e8117d8efcee589f4d96dd2b2eb1d997f96d27d214cf2b7134ad8acf6ab/asn1crypto-0.22.0-py2.py3-none-any.whl (97kB)
Collecting cffi==1.11.5 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 24))
  Downloading https://files.pythonhosted.org/packages/14/dd/3e7a1e1280e7d767bd3fa15791759c91ec19058ebe31217fe66f3e9a8c49/cffi-1.11.5-cp27-cp27mu-manylinux1_x86_64.whl (407kB)
Collecting ConfigArgParse==0.12.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 57))
  Downloading https://files.pythonhosted.org/packages/17/8d/4a41f11b0971017c7001f118be8003da8f7b96b010c66cd792b76658d1e1/ConfigArgParse-0.12.0.tar.gz (41kB)
Collecting configobj==5.0.6 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 60))
  Downloading https://files.pythonhosted.org/packages/64/61/079eb60459c44929e684fa7d9e2fdca403f67d64dd9dbac27296be2e0fab/configobj-5.0.6.tar.gz
Collecting cryptography==2.2.2 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 63))
  Downloading https://files.pythonhosted.org/packages/dd/c2/3a5bfefb25690725824ade71e6b65449f0a9f4b29702cce10560f786ebf6/cryptography-2.2.2-cp27-cp27mu-manylinux1_x86_64.whl (2.2MB)
Collecting enum34==1.1.2 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 83))
  Downloading https://files.pythonhosted.org/packages/6f/e9/08fd439384b7e3d613e75a6c8236b8e64d90c47d23413493b38d4229a9a5/enum34-1.1.2.tar.gz (46kB)
Collecting funcsigs==1.0.2 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 86))
  Downloading https://files.pythonhosted.org/packages/69/cb/f5be453359271714c01b9bd06126eaf2e368f1fddfff30818754b5ac2328/funcsigs-1.0.2-py2.py3-none-any.whl
Collecting idna==2.5 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 89))
  Downloading https://files.pythonhosted.org/packages/11/7d/9bbbd7bb35f34b0169542487d2a8859e44306bb2e6a4455d491800a5621f/idna-2.5-py2.py3-none-any.whl (55kB)
Collecting ipaddress==1.0.16 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 92))
  Downloading https://files.pythonhosted.org/packages/23/6a/813ac29a01e4c33c19c2bded98ac3d4266ebbf0bd2c0eb0020e1c969958d/ipaddress-1.0.16-py27-none-any.whl
Collecting josepy==1.1.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 95))
  Downloading https://files.pythonhosted.org/packages/23/46/30ac29742b03be92e05d1fd9048df6f0902bb0b3b042a7ea76a2b3c30f7e/josepy-1.1.0-py2.py3-none-any.whl (53kB)
Collecting linecache2==1.0.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 98))
  Downloading https://files.pythonhosted.org/packages/c7/a3/c5da2a44c85bfbb6eebcfc1dde24933f8704441b98fdde6528f4831757a6/linecache2-1.0.0-py2.py3-none-any.whl
Collecting mock==1.3.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 102))
  Downloading https://files.pythonhosted.org/packages/b2/50/664a70b87408bb6c14c1af2337efa64eb8d1af80c933531758b8fb41ec25/mock-1.3.0-py2.py3-none-any.whl (56kB)
Collecting ordereddict==1.1 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 105))
  Downloading https://files.pythonhosted.org/packages/53/25/ef88e8e45db141faa9598fbf7ad0062df8f50f881a36ed6a0073e1572126/ordereddict-1.1.tar.gz
Collecting packaging==16.8 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 108))
  Downloading https://files.pythonhosted.org/packages/87/1b/c39b7c65b5612812b83d6cab7ef2885eac9f6beb0b7b8a7071a186aea3b1/packaging-16.8-py2.py3-none-any.whl
Collecting parsedatetime==2.1 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 111))
  Downloading https://files.pythonhosted.org/packages/85/1f/13fc06097e516f6259d62cea502b116451321c96e18a9d0fff9da3442e02/parsedatetime-2.1-py2-none-any.whl
Collecting pbr==1.8.1 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 114))
  Downloading https://files.pythonhosted.org/packages/fc/37/94af8387babb09796d306b18cf94ee5c70388c875a16d8a88e471500452c/pbr-1.8.1-py2.py3-none-any.whl (89kB)
Collecting pyOpenSSL==16.2.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 117))
  Downloading https://files.pythonhosted.org/packages/ac/93/b4cd538d31adacd07f83013860db6b88d78755af1f3fefe68ec22d397e7b/pyOpenSSL-16.2.0-py2.py3-none-any.whl (43kB)
Collecting pyparsing==2.1.8 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 120))
  Downloading https://files.pythonhosted.org/packages/85/b9/188515f35f78533b3f82966a2c3f1a71a86df8b801367ee75a77191a861d/pyparsing-2.1.8-py2.py3-none-any.whl (54kB)
Collecting pyRFC3339==1.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 129))
  Downloading https://files.pythonhosted.org/packages/9b/0a/decfa17e7707afca17d6e9595ff5c79c1c71c74063ad95576f897ed3a9f1/pyRFC3339-1.0-py2.py3-none-any.whl
Collecting python-augeas==0.5.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 132))
  Downloading https://files.pythonhosted.org/packages/41/e6/4b6740cb3e31b82252099994cea751c648b846aa7874343c31d68c2215be/python-augeas-0.5.0.tar.gz (90kB)
Collecting pytz==2015.7 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 135))
  Downloading https://files.pythonhosted.org/packages/c0/28/973f0382c803b21734cd7e97e0590928148ee21b1cbe8f7fed8b506204fb/pytz-2015.7-py2.py3-none-any.whl (476kB)
Collecting requests==2.20.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 149))
  Downloading https://files.pythonhosted.org/packages/f1/ca/10332a30cb25b627192b4ea272c351bce3ca1091e541245cccbace6051d8/requests-2.20.0-py2.py3-none-any.whl (60kB)
Collecting six==1.10.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 152))
  Downloading https://files.pythonhosted.org/packages/c8/0a/b6723e1bc4c516cb687841499455a8505b44607ab535be01091c0f24f079/six-1.10.0-py2.py3-none-any.whl
Collecting traceback2==1.4.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 155))
  Downloading https://files.pythonhosted.org/packages/17/0a/6ac05a3723017a967193456a2efa0aa9ac4b51456891af1e2353bb9de21e/traceback2-1.4.0-py2.py3-none-any.whl
Collecting unittest2==1.1.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 158))
  Downloading https://files.pythonhosted.org/packages/72/20/7f0f433060a962200b7272b8c12ba90ef5b903e218174301d0abfd523813/unittest2-1.1.0-py2.py3-none-any.whl (96kB)
Collecting zope.component==4.2.2 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 161))
Collecting zope.event==4.1.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 164))
Collecting zope.interface==4.1.3 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 167))
Collecting requests-toolbelt==0.8.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 185))
Collecting chardet==3.0.2 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 188))
Collecting urllib3==1.24.1 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 191))
Collecting certifi==2017.4.17 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 194))
Collecting letsencrypt==0.7.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 205))
Collecting certbot==0.30.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 209))
Collecting acme==0.30.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 212))
Collecting certbot-apache==0.30.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 215))
Collecting certbot-nginx==0.30.0 (from -r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 218))
Requirement already satisfied: setuptools>=1.0 in /opt/eff.org/certbot/venv/lib/python2.7/site-packages (from josepy==1.1.0->-r /tmp/tmp.8GW5p7ln97/letsencrypt-auto-requirements.txt (line 95)) (40.6.3)
Installing collected packages: argparse, pycparser, asn1crypto, cffi, ConfigArgParse, six, configobj, enum34, idna, ipaddress, cryptography, funcsigs, pyOpenSSL, josepy, linecache2, pbr, mock, ordereddict, pyparsing, packaging, parsedatetime, pytz, pyRFC3339, python-augeas, urllib3, certifi, chardet, requests, traceback2, unittest2, zope.interface, zope.event, zope.component, requests-toolbelt, acme, certbot, letsencrypt, certbot-apache, certbot-nginx
  Found existing installation: argparse 1.2.1
    Not uninstalling argparse at /usr/lib/python2.7, outside environment /opt/eff.org/certbot/venv
    Can't uninstall 'argparse'. No files were found to uninstall.
  Running setup.py install for pycparser: started
    Running setup.py install for pycparser: finished with status 'done'
  Running setup.py install for ConfigArgParse: started
    Running setup.py install for ConfigArgParse: finished with status 'done'
  Running setup.py install for configobj: started
    Running setup.py install for configobj: finished with status 'done'
  Running setup.py install for enum34: started
    Running setup.py install for enum34: finished with status 'done'
  Running setup.py install for ordereddict: started
    Running setup.py install for ordereddict: finished with status 'done'
  Running setup.py install for python-augeas: started
    Running setup.py install for python-augeas: finished with status 'done'
  Running setup.py install for zope.interface: started
    Running setup.py install for zope.interface: finished with status 'done'
  Running setup.py install for zope.event: started
    Running setup.py install for zope.event: finished with status 'done'
  Running setup.py install for zope.component: started
    Running setup.py install for zope.component: finished with status 'done'
Exception:
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 393, in run
    use_user_site=options.use_user_site,
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/req/__init__.py", line 57, in install_given_reqs
    **kwargs
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/req/req_install.py", line 919, in install
    use_user_site=use_user_site, pycompile=pycompile,
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/req/req_install.py", line 445, in move_wheel_files
    warn_script_location=warn_script_location,
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 583, in move_wheel_files
    outrows = get_csv_rows_for_installed(reader)
  File "/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 565, in get_csv_rows_for_installed
    for fpath, digest, length in old_csv_rows:
ValueError: too many values to unpack
Certbot has problem setting up the virtual environment.
We were not be able to guess the right solution from your pip
output.
Consult https://certbot.eff.org/docs/install.html#problems-with-python-virtual-environment
for possible solutions.
You may also find some support resources at https://certbot.eff.org/support/ .
FYI, that issue is:
+1 Same issue using Debian 9 on AWS
I’m having this exact same issue. I tried upgrading pip, as per other discussion threads, to no avail. I’m on AWS linux.
I had an older version of pip (~9.x) when I originally had this issue. While trying to fix it I upgraded PIP to 19./x and am still seeing this issue. FYI.
This worked for me! You can diff on the original file or just go into the certbot-auto file and add the flags to the two lines described.
It worked for me, sorry for the earlier reply stating it wasn’t. The update hadn’t taken due to permission issues. Thanks!
Confirming - the fix quoted by neurosys-zero worked for me.
Working now for me too (on a Raspbian for Jeedom).
Did not work for me, assuming the only change that was necessary to certbot-auto to add “–no-download” to two lines in the script (shown in the diff in the linked thread). Same issue - “too many values to unpack”.
Fedora release 28 (Twenty Eight)
NAME=Fedora
VERSION=“28 (Server Edition)”
ID=fedora
VERSION_ID=28
It's a different issue to the one fixed by --no-download (pip install certbot-apache fails with pip 19 · Issue #6687 · certbot/certbot · GitHub). Try upgrading pip to 19.0.1.
pip --version
Wow I’m so glad I don’t auto-update - which would be bad for security anyway. Now I only have one broken install of Let’s Encrypt and not dozens. #FAIL
