Cert does not work
district69darts.com
certbot-auto -d www.district69darts.com -d district69darts.com
Congratulations! You have successfully enabled https://www.district69darts.com
and https://district69darts.com
access:
https://district69darts.com: ok
https://www.district69darts.com: SSL_ERROR_RX_RECORD_TOO_LONG
Both domain names are in the same VirtualHost config, ServerName=www.district69darts.com, ServerAlias=district69darts.com
Apache 2.4.25
Debian 9.6 with Kernel 4.9.0-8-amd64
own server
Seems to be working fine to me.
@_az Thank you. Seems to be an issue in my local network. All other domains (20+) work just fine, only this one triggers this SSL error.
Seems to be fine indeed: https://www.ssllabs.com/ssltest/analyze.html?d=www.district69darts.com&hideResults=on
Hi @thalueng
this happens sometimes if http content is sent over a https - port.
But I don't see an error, same with online checks.
So it's only a caching problem of your local browser.
