Please, I'm trying to set up ssl for my raspberry pi docker instance using nginx-proxy-manager, Ive been having problem matching the device IP to my cloudflare dns.
My domain is :
vault0.norugroup.com
norugroup.com
certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-23" --agree-tos --authenticator webroot --email "andhikafadhlanw@icloud.com" --preferred-challenges "dns,http" --domains "norugroup.com,vault0.norugroup.com"
Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Requesting a certificate for norugroup.com and vault0.norugroup.com
Domain: vault0.norugroup.com
Type: connection
Detail: 103.119.141.211: Fetching http://vault0.norugroup.com/.well-known/acme-challenge/1XXGIKqSBIf9b8BTFLSS5xNzzekhk2iRzdv_kvo8IQw: Timeout during connect (likely firewall problem)
Domain: norugroup.com
Type: dns
Detail: no valid A records found for norugroup.com; no valid AAAA records found for norugroup.com
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/letsencrypt-log/letsencrypt.log or re-run Certbot with -v for more details.(
nginx(using nginx-proxy-manager)
raspberrypi os 6.1 ( bookworm)
no
or certbot-auto --version
if you're using Certbot): certbot --version 2.1.0
