Can't issue certs for two domains on one IP with nginx
My domains are:
http://ptif.co.uk and http://ptifscreen.co.uk
certbot certonly \
--expand \
--webroot \
--webroot-path /root/sys/config/tmpsite \
-d ptifscreen.co.uk \
--webroot-path /root/sys/config/tmpsiteptif \
-d ptif.co.uk \
--agree-tos \
--email john@fernholt.myzen.co.uk \
--verbose \
--rsa-key-size 4096 \
--keep-until-expiring \
--preferred-challenges=http
Renewing an existing certificate for ptifscreen.co.uk and ptif.co.uk
http-01 challenge for ptif.co.uk
Using the webroot path /root/sys/config/tmpsiteptif for all unmatched domains.
Challenge failed for domain ptif.co.uk
  Domain: ptif.co.uk
  Type:   unauthorized
  Detail: 2a01:7e00::f03c:93ff:fe20:886d: Invalid response from http://ptif.co.uk/.well-known/acme-challenge/uAAnUQ4lyuf1WR68ZopLVxwGdK7s9VhBUc_VsHtuqNI: 404
I am using the Nginx Docker image: nginx:latest
Nginx is in a Docker Container, Certbot is Not in a Container. Certbot is installed on the host.
Debian GNU/Linux 11 (bullseye)
My hosting provider is:
Linode
I can login as root.
No.
I am using certbot 2.6.0
My problem:
The problem above is using Certbot on the host but uses Nginx which is in a Docker container. So, the first hurdle is deciding if the problem is Nginx config, Docker compose, or the certbot command I'm using. I can't expect any help with docker or nginx but perhaps I could be pointed to some information somewhere that might help.
Perhaps I am not understanding what certbot/Let's encrypt needs. For example, in my nginx, both domains are using root /tmp/acme-challenge;
I did get one certificate successfully for ptifscreening.co.uk, but that was requested on its own and not at the same time as ptif.co.uk.
My testing nginx configuration file is:
    listen 80;
    listen [::]:80;
    server_name ptifscreen.co.uk;
	root /usr/share/nginx/html;
	index index.html;
    listen 80;
    listen [::]:80;
    server_name ptif.co.uk;
	root /usr/share/nginxptif/html;
	index index.html;
The test docker compose file is:
version: '3.7'
services:
  nginx:
    image: nginx:latest
    container_name: nginx
    ports:
      - "80:80"
    volumes:
      - ./config/nginx_init:/etc/nginx/conf.d
      - /etc/letsencrypt:/etc/letsencrypt:ro
      - /tmp/acme-challenge:/tmp/acme-challenge
      - /var/log/nginx:/var/log/nginx
      - ./config/tmpsite:/usr/share/nginx/html
      - ./config/tmpsiteptif:/usr/share/nginxptif/html
Thank you for any guidance.
Hi @johnfern, and welcome to the LE community forum :slight_smile:
Those don't match.
[webroot path should equal root path]
Please continue your testing with the staging environment [until all test have passed].
Well @rg305 you are a saviour. Thank you very much indeed.
