Can't Issue a certificate for a test domain
My domain is: www.tyt.com.ye
I ran this command: Let’s Encrypt Cert request through Plesk
Could not issue an SSL/TLS certificate for tyt.com.ye
Details
Could not issue a Let’s Encrypt SSL/TLS certificate for tyt.com.ye . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/3812788469.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: query timed out looking up CAA for com.ye
My web server is (include version): Plesk Obsidian
The operating system my web server runs on is (include version): Cloudlinux
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Obsidian
Hi @moayedyagout
the name server of com.ye is buggy. Checking your domain - https://check-your-website.server-daten.de/?q=tyt.com.ye
X Fatal error: Nameserver doesn't support TCP connection: sah1.ye: ServerFailure
X Fatal error: Nameserver doesn't support TCP connection: sah1.ye / 195.94.0.34: ServerFailure
X Fatal error: Nameserver doesn't support TCP connection: sah1.ye / 2a02:e280:8:d000::34: ServerFailure
X Fatal error: Nameserver doesn't support TCP connection: sah2.ye / 2a02:e280:8:d000::35: Timeout
X Nameserver Timeout checking Echo Capitalization: sah2.ye / 2a02:e280:8:d000::35
X Nameserver Timeout checking EDNS512: sah2.ye / 2a02:e280:8:d000::35
The CAA check has no error, the TXT check has a lot of errors:
Server failure - The name server was unable to process this query due to a problem with the name server
If possible, create a CAA entry with tyt.com.ye.
Then the CAA entry of com.ye isn't checked.
If that's not possible, that's bad.
excuse my lack of knowledge,
Let me state what I understood from your reply.
My NameServer ( SAH1.YE ) has bugs and it cannot perform TCP connections? any ideas how to fix this ?
and how should my zone file ( tyt.com.ye ) be written? is there something I must add?
what’s a CAA? is it a record I need to add to my zone file? and if yes, what should I add ?
Thank You
