Hi all,
I have a test server https://behit-dev.atomik.app and the auto-renew was failing (that's not the issue, see below).
We have Apache listening on ports 80/443 and forwarding to a Tomcat in the back via mod_jk (Working with mod_jk)
The only way the cert renew worked, was by manually removing the configuration on the site*.conf files for the mod_jk that makes Apache talk to Tomcat, that is:
<VirtualHost *:80>
ServerAdmin pablo.pazos@cabolabs.com
ServerName behit-dev.atomik.app
ErrorLog /var/log/apache2/domains/behit-dev.atomik.app/error.log
CustomLog /var/log/apache2/domains/behit-dev.atomik.app/access.log combined
**JkMount /* atomik <<< NEEDED TO COMMENT THIS**
Did the same on the ...le-ssl.conf site file, just commented the JkMount line.
With that the renew worked. Now my question: how can I automate the renewal without manually logging to the server and commenting the site config files?
Of course, after that, I need to uncomment everything manually again.
I don't know the internals of the certbot and the auto-renew process, I just see on my logs that a cron runs daily trying to renew, and some snap stuff. If I can access the script to add something that comments the JkMount line, that would be useful.
Also if you have any tips on how to automatically renew on this context it will be much appreciated, maybe I'm missing something.
Apache 2.4
Ubuntu 23.04
Linode
certbot --version
certbot 2.6.0
