Cannot renew using certbot renew
My domain is: lifemaxuk.co.uk
lifemax@lifemaxuk:/etc/letsencrypt/renewal$ certbot renew --cert-name lifemaxuk.co.uk.conf
The following error was encountered:
[Errno 13] Permission denied: ‘/var/log/letsencrypt/.certbot.lock’
Either run as root, or set --config-dir, --work-dir, and --logs-dir to writeable paths.
lifemax@lifemaxuk:/etc/letsencrypt/renewal$ sudo certbot renew --cert-name lifemaxuk.co.uk.conf
No certificate found with name lifemaxuk.co.uk.conf (expected /etc/letsencrypt/renewal/lifemaxuk.co.uk.conf.conf).
Processing /etc/letsencrypt/renewal/lifemaxuk.co.uk.conf
http-01 challenge for lifemaxuk.co.uk
http-01 challenge for goodlifeguide.co.uk
Waiting for verification…
Attempting to renew cert (lifemaxuk.co.uk) from /etc/letsencrypt/renewal/lifemaxuk.co.uk.conf produced an unexpected error: Failed authorization procedure. goodlifeguide.co.uk (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://goodlifeguide.co.uk/.well-known/acme-challenge/t0CmmRD-klB8743Xw1bmzoS553w3rWobeOeNg387-Oo: “\n\n404 Not Found\n\n
Not Found
\n<p”. Skipping.
/etc/letsencrypt/live/lifemaxuk.co.uk/fullchain.pem (failure)
My web server is (include version): apache
The operating system my web server runs on is (include version): ubuntu 16.04
My hosting provider, if applicable, is: simply hosting
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): plesk
Hi @williampatey
run it as root:
sudo certbot renew
But: There are two certificates created today:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:lifemaxuk.co.uk;issuer_uid:4428624498008853827&lu=cert_search
Installed is a certificate created 2018-09-05.
PS: Oh, now is the certificate installed created today :wink:
Running as root does not solve the issue. Gives me the same response.
Looks like your goodlifeguide.co.uk is broken.
  • Create (if not exist) two directories in your webroot of this domain - /.well-known/acme-challenge/ - there a file 1234 (without extension). Try to load this file via http://goodlifeguide.co.uk/.well-known/acme-challenge/1234
  • share your apache configuration and your certbot renew conf file (see /etc/letsencrypt/renewal).
