Can someone help me solve this problem?
alguien que me eayude a dar solucuion este tema
Domain: xxxxxxxxxxx.com
Detail: 2606:4700:30::681xxxxx: Invalid response from http://xxxxxxxx.com/.well-known/acme-challenge/-p4xHUQ4m_qk9bT6xC-yMwcvrF7OUBaOChRN-Xf6k: 403
It's difficult to tell without a real domain name but the most common cause of this issue is that your DNS has an IPv6 record (AAAA record ) that doesn't point to your server.
This is commonly because your DNS provider has pointed that at a domain parking page, but your IPv4 A record probably points to the correct IP address of your server.
Let's Encrypt will try the IPv6 version of your site if your DNS states that one is available, which it currently does.
