Can not renew my LE certificate! Why?
Well, I only promoted the www address for my NextCloud.
I initially understood it wrong and thought certs cannot contain www, so I started without and corrected it afterwards. The www worked for me all the years.
Anyway, let's try to fix this.
The output of sudo certbot certificates:
Found the following certs:
  Certificate Name: woestmeyer.com
    Serial Number: 3f2f51356e3aa765d3f097d282332132fb9
    Key Type: RSA
    Domains: woestmeyer.com
    Expiry Date: 2023-08-05 05:20:18+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/woestmeyer.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/woestmeyer.com/privkey.pem
  Certificate Name: www.woestmeyer.com
    Serial Number: 3ac936a6ee5ee8f880b0c610c092a37ecdc
    Key Type: RSA
    Domains: www.woestmeyer.com
    Expiry Date: 2023-08-05 05:27:27+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/www.woestmeyer.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/www.woestmeyer.com/privkey.pem
contents of: /etc/apache2/sites-enabled/000-default-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
	# specifies what hostname must appear in the request's Host: header to
	#ServerName www.example.com
	DocumentRoot /var/www/html
	# error, crit, alert, emerg.
	# modules, e.g.
	#LogLevel info ssl:warn
ServerName www.woestmeyer.com
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/www.woestmeyer.com/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.woestmeyer.com/privkey.pem
<IfModule mod_headers.c>
 Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
</VirtualHost>
</IfModule>
Okay, that way?
/var/www/html is my NC installation.
If you don't use that name then you should delete that cert
sudo certbot delete --cert-name woestmeyer.com
After doing that, is this successful?
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/www.woestmeyer.com.conf
Account registered.
Simulating renewal of an existing certificate for www.woestmeyer.com
Congratulations, all simulated renewals succeeded:
  /etc/letsencrypt/live/www.woestmeyer.com/fullchain.pem (success)
Yes! Deleted the unused one.
The site now comes up with:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
I think, the logs are the NC logs to look up, right?
Yes, the certs look fine now. They are renewing successfully and connections to your www domain use the current cert. Note you have an IP address in the DNS for your root name so requests can be made to that name. And, HTTPS requests fail due to mis-matched domain name but if you don't care I don't care :slight_smile:
The HTTP 500 error is not related to the certs. I didn't see anything in your Apache config that causes that. But, what is in this folder?
ls -l /etc/apache2/sites-enabled/
Also, did you change anything in your base Apache config recently?
lrwxrwxrwx 1 root root   35 Sep 16  2018       000-default.conf -> ../sites-available/000-default.conf
lrwxrwxrwx 1 root root   52 Sep 16  2018       000-default-le-ssl.conf -> /etc/apache2/sites-available/000-default-le-ssl.conf
-rw-r--r-- 1 root root 1790 Okt 22  2019          000-default-le-ssl.conf.save
I noticed some apache2 updates recently, which I enrolled certainly - mostly automatically.
What is in that file? And do you know if your base Apache config would include a file with a .save extension?
I contains mostly the same as the conf without the *.save extension , see above.
Unfortunately not. If, then I made this long time ago. Or edited it, due to new config requirements of NC.
<VirtualHost *:443>
	# modules, e.g.
</IfModule>
</VirtualHost>
</IfModule>
 Header always set Strict-Transport-Security "max-age=15552000; includeSubDomai>
</IfModule>
Just to be safe you should move that .save file to your /sites-available/ folder or somewhere else if you still need it.
As for the http 500, you should see some errors in the Apache error logs. It is also affecting just HTTP requests to your root domain so is not cert related. Something must be in your base Apache config that is causing this.
I know you don't care about the root name requests but this just helps locate the problem.
It is a little odd that the Strict-Transport-Security header is set for this HTTP request. Normally that is only used for HTTPS requests so maybe this is a clue on what to look at in your Apache config.
curl -I http://woestmeyer.com
HTTP/1.1 500 Internal Server Error
Date: Sun, 07 May 2023 14:42:29 GMT
Server: Apache/2.4.52 (Ubuntu)
Strict-Transport-Security: max-age=15768000; preload
Referrer-Policy: no-referrer
X-Content-Type-Options: nosniff
X-Frame-Options: SAMEORIGIN
X-Permitted-Cross-Domain-Policies: none
X-Robots-Tag: none
X-XSS-Protection: 1; mode=block
Upgrade: h2,h2c
Connection: Upgrade, close
Content-Type: text/plain; charset=utf-8
Do you think I should better start over with my NC installation?
As it's only for private use, it's no really a big deal. It has several odd configuration changes and additions over the years, that I did not track by 100 %.
I don't know NC well enough to say.
Guess what, I'll do that. A fresh start once in awhile can do wonders. Tracking back old errors is a waste of time.
Now I understand it much more than in 2018, and the installation / updating is not a nightmare anymore.
When there's another problem with the certs, I'll be back here.
Thank you for your help, every1 & your patience!
It still isn't :frowning:
The file has several opens with no matching closings.
Anyway.
I made it all new today. About an hour of work.
The process of certification worked like a charme. So, I'm all good (again) now!
