Calls to .well-known every 5 seconds for more than 24 hours
I am receiving calls to .well-known every 5 seconds and have been for the last 24 hours.
The requests look like this:
“GET https://x.y.z/.well-known/acme-challenge/redacted” 403 554 “Go-http-client/2.0”
And as you can see the request is routed to my default pod which is a Java Spring server that responds with 403 Forbidden.
How can I stop these requests from being made?
Thank you!
Will disclose later if absolutely necessary
Kubernetes cluster with cert-manager (currently uninstalled)
Google/GKE
Yes
No
The version of my client is:
Was cert-manger 0.2.5 but currently uninstalled
When this is resolved I intend to use 0.7.0
Hi @bbzg
what ip address creates these requests?
:wave: Hi @bbzg, welcome to the community forum.
We have seen lots of bugs that end up generating excessive traffic to our ACME server from this version of cert-manager.
Are you 100% sure it is fully uninstalled? The ACME server wouldn't be making HTTP-01 validation requests without an ACME client POSTing challenges.
Can you share your domain name? It would make it possible for me to check the server-side logs to see what user agent is initiating the challenges to confirm whether it is cert-manager.
If it's just using a generic Go user-agent, it's not the Let's Encrypt validation servers.
Plus it's using HTTPS -- if it was from Let's Encrypt, there would be an equal number of HTTP requests as well.
Good point! Maybe its a self-check from certmanager?
Thanks for the help guys <3,
I tracked it down to a misconfiguration in another cluster that had been configured with faulty subdomain.
