Unknown subcommand "admin".
File "test/integration-test.py", line 149, in <module>
main()
File "test/integration-test.py", line 93, in main
run_chisel(args.test_case_filter)
File "test/integration-test.py", line 116, in run_chisel
value()
File "/boulder/test/v2_integration.py", line 1609, in test_admin_revoker_batched
run(["./bin/admin",
File "/boulder/test/helpers.py", line 53, in run
return subprocess.check_call(cmd, stderr=subprocess.STDOUT, **kwargs)
File "/usr/lib/python3.8/subprocess.py", line 364, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['./bin/admin', '-config', 'test/config/admin.json', '-dry-run=false', 'revoke-cert', '-serials-file', '/tmp/tmplajcv7si/tmpdoqnax4t.test_admin_revoker_batched.serials.hex', '-reason', 'unspecified', '-parallelism', '2']' returned non-zero exit status 1.
08:37:18.858958 6 akamai-purger 2f7Ciwo Shutting down; queue is already empty.
FAILURE while running integration
this only happens when it's run on wsl, not on native, but it fails on anything on docker over wsl: (both docker desktop on window calling wsl and docker directly installed on wsl ubuntu: may better asked on wsl forum but error itself is on boulder side errror that admin is not registerd while compiling, so it'd known better on here
