Beginner - "DNS problem: SERVFAIL looking up A for..."
My domain is: lucynet.org
I ran this command: started swag container
Domain: overseerr.lucynet.org
Type: dns
Detail: DNS problem: SERVFAIL looking up A for overseerr.lucynet.org - the domain's nameservers may be malfunctioning; no valid AAAA records found for overseerr.lucynet.org
ERROR: Cert does not exist! Please see the validation error above. The issue may be due to incorrect dns or port forwarding settings. Please fix your settings and recreate the container
My web server is (include version): unknown
The operating system my web server runs on is (include version): Unraid 6.12.10, Linuxserver.io swag docker
My hosting provider, if applicable, is: squarespace
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 5.1.0
I'm running letsencrypt to setup a reverse proxy to access overseerr.lucynet.org. I don't have a great understanding of all of this but I'm trying to learn. PortChecker says ports 80 and 443 are open.
Opnsense firewall rules:
Squarespace DNS CNAME setup:
Duckdns:
docker setup:
domain forward setup:
Welcome to the Let's Encrypt Community.
Try running the FQDN through Let's Debug. You will see that you are returning an HTTP 401. That is going to break your ACME challenge.
Your DNSviz report doesn't look great, either, but focus on eliminating that HTTP 401 response first.
Thanks for looking into things. What should I be looking at to eliminate the 401 response?
Additionally, since originally posting, I added some CNAME records shown below and the letsencrypt server was able to start
Using Let's Encrypt as the cert provider
SUBDOMAINS entered, processing
Sub-domains processed are: overseerr.lucynet.org
E-mail address entered: [redacted
http validation is selected
Certificate exists; parameters unchanged; starting nginx
The cert does not expire within the next day. Letting the cron script handle the renewal attempts overnight (2:08am).
[custom-init] No custom files found, skipping...
[ls.io-init] done.
Server ready
That question is best directed to the support channels for the server you are running that is returning that response. Presumably that is a swag container. I have no idea where you can find support for that, but you need a properly functioning server environment before you start trying to issue certificates.
Did you configure firewall rules or other access restrictions on port 80?
Your web server is nginx. At least that is the server currently replying to HTTP requests to your domain. You can tell by viewing the response headers in an HTTP request.
The --standalone option is a poor choice when using a web server. You should be using --webroot or even the --nginx option instead.
Where did you see instructions that said to use --standalone?
So letsencrypt is issuing the certificates now that I added the CNAMEs.
Generating new certificate
Saving debug log to /config/log/letsencrypt/letsencrypt.log
Account registered.
Requesting a certificate for overseerr.lucynet.org
Certificate is saved at: /config/etc/letsencrypt/live/overseerr.lucynet.org/fullchain.pem
Key is saved at: /config/etc/letsencrypt/live/overseerr.lucynet.org/privkey.pem
This certificate expires on 2026-02-11.
NEXT STEPS:
  • The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See User Guide — Certbot 5.2.0.dev0 documentation for instructions.
New certificate generated; starting nginx
[ls.io-init] done.
Server ready
What you're saying is that this is most likely an issue with my Unraid server config? I'll go post over on those forums. Appreciate the responses.
As for port 80, I forwarded it to internal port 180 on my Unraid machine. My port forward setup is shown in a screenshot above.
I figured out the 401 error - I had uncommented the highlighted lines in the config file while messing around earlier. Recommenting them fixed the issue and now I'm up and running.
