Automation for request/renewal wildcard certs on Nginx
My domain is: lyte.sg
I ran this command: No certbot command to automate wildcard cert request from Nginx config
It produced this output: N/A
My web server is (include version):Nginx 1.14.0-0ubuntu1.6
The operating system my web server runs on is (include version): Ubuntu Server 18.04
My hosting provider, if applicable, is: DNS - AWS Route53
I have successfully tested a certbot --nginx setup for a static FQDN test certificate (e.g. static.domain.net). However, when I changed Nginx server block to wildcard style *.domain.net it looks like Certbot does not recognise/support that
> # certbot --nginx
> Saving debug log to /var/log/letsencrypt/letsencrypt.log
> Plugins selected: Authenticator nginx, Installer nginx
> No names were found in your configuration files. Please enter in your domain
> name(s) (comma and/or space separated) (Enter 'c' to cancel): c
> Please specify --domains, or --installer that will help in domain names autodiscovery, or --cert-name for an existing certificate name.
I’ve look through a number of articles written by different people on the procedure for request wildcard certs from Let’s Encrypt, and they all do so as manual steps to launch certbot certonly + DNS plugin adjustments, then manually re-configuring Ngnix after obtaining the cert.
I guess there’s no combo procedure to auto-detect from Nginx the wildcard domains and interacting with both LE and Route53?
Hi @icelava
that's not possible.
If you use --nginx, the http challenge is used to validate your domain name.
But if you want to create a wildcard certificate (which has nothing to do with a wildcard vHost), then you have to use dns-validation.
So --nginx as authenticator can't be used to validate a wildcard certificate.
Read
Certbot’s Route 53 DNS plugin is available in the python3-certbot-dns-route53 package.
You can combine the Route 53 authenticator and the Nginx installer with “certbot -a dns-route53 -i nginx”.
https://certbot-dns-route53.readthedocs.io/en/stable/
In this case it will indeed not be able to “auto-detect” the domains from the nginx configuration; they would be specified interactively, or via the -d option on the command line. But the method suggested by @mnordhoff is the recommended one if you’re going to use Certbot for this.
My boss eventually did not like the idea of granting the Certbot process management access of entire domain zones, so he opted for delegation to sub-domains with the help of ACME-DNS. We tested it out and it appears to meet our requirements, so we’ve abandoned the Route53 plug-in approach.
