Hi ! The thing comes from this topic:
The thing is now, I use this command to renew cert and it works perfect(or run without errors):
certbot certonly
--dns-digitalocean
--dns-digitalocean-credentials ~/.secrets/certbot/digitalocean.ini
--dns-digitalocean-propagation-seconds 60
-d '*.demoswp.com'
-d demoswp.com
How can I do to renew the cert ?
I had in my crontab this line:
/usr/local/bin/certbot renew
does it will work ?
AND ... The console said me certificate expire in 2019/08/08 but certificate in chrome or in webpages said previous expiration date (2019-05-27)
/usr/local/bin/certbot certificates
Found the following certs:
Certificate Name: demoswp.com
Domains: *.demoswp.com demoswp.com
Expiry Date: 2019-08-08 17:22:28+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/demoswp.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/demoswp.com/privkey.pem
https://www.ssllabs.com/ssltest/analyze.html?d=demoswp.com
demoswp.com
certbot certonly
--dns-digitalocean
-d '*.demoswp.com'
-d demoswp.com
Plugins selected: Authenticator dns-digitalocean, Installer None
dns-01 challenge for demoswp.com
Unsafe permissions on credentials configuration file: /root/.secrets/certbot/digitalocean.ini
Waiting 60 seconds for DNS changes to propagate
Your cert will expire on 2019-08-08. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew *all* of your certificates, run
"certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
Apache
Ubuntu 18.04
DigitalOcean
nop
certbot 0.28.0
