aplanetbit.com
sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/aplanetbit.com.conf
http-01 challenge for aplanetbit.com
Attempting to renew cert (aplanetbit.com) from /etc/letsencrypt/renewal/aplanetbit.com.conf produced an unexpected error: Failed authorization procedure. aplanetbit.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://aplanetbit.com/.well-known/acme-challenge/bRlBmyiaEP8cwH-vgIsB2BZj5HUR4wfQIbYAd8jxLzs: Timeout during connect (likely firewall problem). Skipping.
Server version: Apache/2.4.38 (Raspbian)
Server built: 2020-08-25T20:08:29
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
Yes, I can login to a root shell in my raspberry pi
I'm using the CLI
or certbot-auto --version
if you're using Certbot):
certbot 0.31.0
Could you give a hand with this issue?
Thanks.
