Auto and Manual Cert renewal failed
My domain is: openhab.beatrixlay.com
I ran this command: sudo certbot renew --dry-run -v
It produced this output:`Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /etc/letsencrypt/renewal/openhab.beatrixlay.com.conf
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for openhab.beatrixlay.com
http-01 challenge for openhab.beatrixlay.com
Using the webroot path /var/www/openhab.beatrixlay.com for all unmatched domains.
Challenge failed for domain openhab.beatrixlay.com
Domain: openhab.beatrixlay.com
Type: connection
Detail: 96.245.54.64: Fetching http://openhab.beatrixlay.com/.well-known/acme-challenge/b7yL5oTpHwH3mC9bH2D16VPye24ZCX3-Epo2gx4Yo54: Timeout during connect (likely firewall problem)
Failed to renew certificate openhab.beatrixlay.com with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/openhab.beatrixlay.com/fullchain.pem (failure)
The operating system my web server runs on is (include version): Debian 12 bookworm
My hosting provider, if applicable, is: self
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.1.0
Welcome @brianlay
A couple things ... the main one is something is blocking HTTP (port 80) requests to your domain. Those worked on Nov14 when you last got a cert so something changed since then.
This is a good test site to check changes you make: Let's Debug
The other thing is your nginx server is not using the most recent cert you got on Nov14. It is using the cert you got on Nov6 which expires very soon. See: SSL Checker
That can be caused by something as simple as not reloading nginx after getting a new cert. Or, you did something different on Nov14 to get that cert that your nginx config does not know about.
Thanks for the quick response.
Let me provide a little context for what I'm doing.
I'm using nginx as a reverse proxy for my home automation server on my home network.. both are on separate machines.
currently only port 443 is open to the nginx server.
so yes port 80 is blocked, but maybe it wasn't when I originally set everything up.
Can I get the renewal to come thorough 443, or do I need to open up port 80 for that purpose.?
Yes, you will
I opened up port 80 on my router but still no joy.
Here is my nginx configuration
        listen 80;
        server_name         openhab.beatrixlay.com;
        listen               443 ssl;
        #Cross-Origin Resource Sharing
        add_header  'Access-Control-Allow-Origin' '*' always;
        add_header  'Access-Control-Allow_Credentials'  'true' always;
        add_header  'Access-Control-Allow-Headers' 'Authorization,Accept.Origin,DNT,X-CustomHeader,Keep-Alive,User=Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Content-Range, Range' always;
        add_header  'Access-Control-Allow-Methods' 'GET,POST,OPTIONS,PUT,DELETE,PATCH' always;
        add_header  Set-Cookie X-OPENHAB-AUTH-HEADER=1;
        ssl_certificate        /etc/letsencrypt/live/openhab.beatrixlay.com/fullchain.pem;
        ssl_certificate_key    /etc/letsencrypt/live/openhab.beatrixlay.com/privkey.pem;
        add_header             Strict-Transport-Security "max-age=31536000";
            proxy_pass                          http://192.168.1.153:8080;
            proxy_set_header Host               $http_host;
            proxy_set_header X-Real-IP          $remote_addr;
            proxy_set_header X-Forwarded-For    $proxy_add_x_forwarded_for;
            proxy_set_header X-Forwared-Proto   $scheme;
            proxy_read_timeout                  3600;
            auth_basic                          "Username and Password Required";
            auth_basic_user_file                /etc/nginx/.htpasswd;
            proxy_set_header Authorization      "";
                #try_files $uri $uri/ =404;
          root                               /var/www/openhab.beatrixlay.com;
So maybe I need to revise the config?
got it working by revising the nginx configuration.
Added to the listen 80 section
        listen 80;
        return 301          https://$server_name$request_uri;
        listen               443 ssl;
hopefully this might help someone with a similar issue
Well, glad it is working but that wasn't how I would recommend doing it.
The reason that worked is you have a root statement in your port 443 server block that matches the webroot path you used to get the cert.
Had you just added the same root statement to your port 80 server block you'd have gotten it too and more efficiently.
We usually have people setup two location blocks to process the challenge in port 80 and redirect all others to https(port 443). I don't have an example on this machine now and since you're working that's fine.
Here is an nginx sample for Certbot --webroot. Setup a port 80 (HTTP) server block like:
    listen 80;
    listen [::]:80;     # if using IPv6
    server_name example.com www.example.com;
        root /var/certbot;       # make/use folder as you prefer
thanks and I still needed to open port 80 on the router?
Yes, the comms "channel" needs to be open to whatever is handling port 80 (nginx in your case)
thanks for the detailed explanation!
Even though I successfully renewed the cert, it appears the server is not using it.
When I try to connect I get a warning.
of course it would have helped to restart the server...
Yes :slight_smile: You can add a --deploy-hook so that Certbot reloads nginx each time it gets a fresh cert.
If you just have the one cert, or all of them use --webroot and nginx, do this command to add it to that cert's renewal profile
sudo certbot renew --deploy-hook X
Where X is the quoted command to reload nginx. Probably something like:
"systemctl reload nginx"
