Hi, I am getting 404 errors when using certbot to set up https. I am using a cloned server instance on which I had successfully set up certificates for a different domain. On this cloned server I removed previous certbot settings, before starting again, but perhaps this has contributed to the errors I'm getting?
My index.html for mikekelly.org is accessible via the browser. I also tried setting up a test file here http://mikekelly.org/.well-known/acme-challenge/test.txt which I can also access via the browser. I manually created the .well-known/acme-challenge folder.
Thanks for any suggestions:
My domain is: mikekelly.org
I ran this command: sudo certbot --nginx
Domain: www.mikekelly.org
Detail: Invalid response from http://www.mikekelly.org/.well-known/acme-challenge/GdA9yuQEkX4Fp-ihb4w01bHgVo-vCtvgaXLIUt8Y8tk [2a06:1002::5d5a:926b]: "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 3.2 Final//EN\">\n<title>404 Not Found</title>\n<h1>Not Found</h1>\n<p>The requested URL was"
Domain: mikekelly.org
Detail: Invalid response from http://mikekelly.org/.well-known/acme-challenge/W5yErklSz2dWRqpP_9uR4GkaEu2nXwsNbMHXIwImp3o [2a06:1002::5d5a:926b]: "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 3.2 Final//EN\">\n<title>404 Not Found</title>\n<h1>Not Found</h1>\n<p>The requested URL was"
My web server is (include version): nginx 1.18.0
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: vultr.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.19.0
rg305
September 30, 2021, 1:41pm
2
Hi @mikekelly , welcome to the LE community forum
LE prefers IPv6 over IPv4 when present.
As seen in the error/failure message, the IP used is the IPv6 address.
You need to ensure the IPv6 address works (or remove it from DNS).
curl -Iki4 www.mikekelly.org
HTTP/1.1 200 OK
Server: nginx/1.18.0 (Ubuntu)
Date: Thu, 30 Sep 2021 13:39:02 GMT
Content-Type: text/html
Content-Length: 281
Last-Modified: Tue, 28 Sep 2021 16:15:58 GMT
ETag: "61533fbe-119"
Accept-Ranges: bytes
curl -Iki6 www.mikekelly.org
HTTP/1.1 403 Forbidden
Connection: close
Cache-Control: no-cache
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
Content-Security-Policy: frame-ancestors 'self'
Content-Length: 3449
Address: 93.174.10.103
Aliases: www.dailyecho.co.uk
The IPv4 and IPv6 address are hosted by different AS networks, so I'm guessing one or the other is incorrect.
rg305
September 30, 2021, 1:49pm
4
petercooperjr:
Good find. Likely: stale DNS info (from a previous hosting plan).
So many people overlook IPv6.
Ah, thank you! I will try updating the DNS settings and will confirm if successful.
I believe the IPv6 addresses are now correct. However now I get a 401 error when trying to create the certificates:
Detail: Invalid response from http://mikekelly.org/.well-known/acme-challenge/zkFcLUcg2m8lq4LwOMCOjrGqZiq3a9EiubIQdJq-4uQ [2001:19f0:6c01:1afb:5400:3ff:fe97:8219]: "<html>\r\n<head><title>401 Authorization Required</title></head>\r\n<body>\r\n<center><h1>401 Authorization Required</h1></center>\r\n<h"
Detail: Invalid response from http://www.mikekelly.org/.well-known/acme-challenge/gNR9eV0uLkGpMUlcfzPK1eS4kFbBFiQ_C7eeaiuc7Kc [2001:19f0:6c01:1afb:5400:3ff:fe97:8219]: "<html>\r\n<head><title>401 Authorization Required</title></head>\r\n<body>\r\n<center><h1>401 Authorization Required</h1></center>\r\n<h"
I guess I could simply remove the DNS AAAA entries? I would be happier if I could get IPv6 up and running.
rg305
September 30, 2021, 3:48pm
7
I still get:
Connection: close
Let's have a look at your nginx config:
sudo nginx -T
I get this:
HTTP/1.1 200 OK
Date: Thu, 30 Sep 2021 17:15:20 GMT
Content-Length: 281
Here's the output from sudo nginx -T:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
listen 80 default_server;
# SSL configuration
root /home/mike/doubleelephant/dist/;
server_name _;
try_files $uri $uri/ =404;
auth_basic "Password required";
auth_basic_user_file /etc/nginx/.htpasswd;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/mikekelly.org:
upstream backend {
server localhost:3000; #node app address
listen 80;
server_name mikekelly.org www.mikekelly.org;
root /home/www/html/;
location /api {
rewrite ^/api(/.*) $1 break;
proxy_pass http://backend;
proxy_set_header Host $host;
# Following is necessary for Websocket support
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
location /research {
alias /var/www/html/research/server/public/;
index index.html index.htm;
try_files $uri $uri/ /index.html =404;
root /var/www/html/;
client_max_body_size 20M;
rg305
September 30, 2021, 5:27pm
9
Try changing:
listen 80;
To:
listen 80;
listen [::]:80; ### add this line ###
rg305
September 30, 2021, 5:28pm
10
Also, please show:
sudo netstat -pant | grep Ei 'nginx|80|443'
That fixed it, thanks so much for your help with this!
I didn't have success running the netstat line: grep: nginx|80|443: No such file or directory
rg305
September 30, 2021, 5:43pm
12
Beautiful!
Glad to have helped out
Cheers from Miami
#FreeCUBA
system
Closed
October 30, 2021, 5:44pm
13
