Ok yeah I see because I took that command from the rwssl debug for what was failing, and it's using the pip package versus snap https://github.com/rehmatworks/serverpilot-letsencrypt/blob/master/requirements.txt#L8
And there is the culprit!
Line one from my first post:
- PIP [BROKEN]
- SNAP [WORKS LIKE A CHARM]
If you knew it was PIP, then just replace APT command with PIP command.
And leave only the SNAP version.
I gave you the answer you needed 6 hours ago.
[and then also prodded you towards finding other problems you didn't even know you had]
I'm glad you got your life in order.
Now back to my so called life.
[getting 99 slayer...]
Cheers from Miami
I appreciate your help @rg305 I didn't realize that pip was also installing a package, it was an oversight on my part. I'm still running into issues but I'll work through all the things you gave me above and see if I can fix it. Enjoy your 99 slayer
If you do get overwhelmed...
There are plenty of nice, and knowledgeable, people here that volunteer their time to help out.
All sorted out. Thank you! Let me know how I can send you a beer or a coffee.
Rip did this... he's delirious.
To be fair:
