Hello, I have a request for help regarding two certificates: ASUS and QNAP. Regarding QNAP, the server correctly registers the certificate and shows in the GUI that it is active … my_domain1111.myqnapcloud.com and I receive an email from Let’s Encrypt that the domain name my_domain.myqnapcloud.com will expire soon.
The ASUS router was all right with the domain my_domain.asuscomm.com and suddenly the update was blocked with the status “update”. I will add that both devices work on the same external IP address. I know that a similar topic was already on the forum, but I can not deal with this problem. Can I ask for some help and tips on what to do?
Regards Darek
(sorry for my english)
Hello, will no one help me or will tell me what to do? Asus says that everything is OK and I still have a problem with the certificate … The router logs show …:
_Jun 2 19:20:20 kernel: /usr/sbin/acme-client: https://acme-v01.api.letsencrypt.org/acme/challenge/87kbDWr4kgSbk971nBkS2yXXKHCyq1_2vRfImAsCcKg/4927343449: bad response
Jun 2 19:20:20 kernel: /usr/sbin/acme-client: transfer buffer: [{ “type”: “http-01”, “status”: “invalid”, “error”: { “type”: “urn:acme:error:connection”, “detail”: “Fetching http://my_domain.asuscomm.com/.well-known/acme-challenge/dXlGFdgzhwWHB1fE9JKDTizyEm8B2K2RC9VyYks-gvc: Timeout during connect (likely firewall problem)”, “status”: 400 }, “uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/87kbDWr4kgSbk971nBkS2yXXKHCyq1_2vRfImAsCcKg/4927343449”, “token”: "dXlGFdgzhwWHB1fE9JKDTizyEm8B2K2RC9VyY
Jun 2 19:25:01 rc_service: service 1974:notify_rc restart_letsencrypt
Jun 2 19:25:07 kernel: /usr/sbin/acme-client: https://acme-v01.api.letsencrypt.org/acme/new-authz: bad HTTP: 429
Jun 2 19:25:07 kernel: /usr/sbin/acme-client: transfer buffer: [{ “type”: “urn:acme:error:rateLimited”, “detail”: “Error creating new authz :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 }] (189 bytes)
Jun 2 19:30:01 rc_service: service 2400:notify_rc restart_letsencrypt
Jun 2 19:30:08 kernel: /usr/sbin/acme-client: https://acme-v01.api.letsencrypt.org/acme/new-authz: bad HTTP: 429
Jun 2 19:30:08 kernel: /usr/sbin/acme-client: transfer buffer: [{ “type”: “urn:acme:error:rateLimited”, “detail”: “Error creating new authz :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 }] (189 bytes)
Jun 2 19:35:01 rc_service: service 2831:notify_rc restart_letsencrypt
Jun 2 19:35:09 kernel: /usr/sbin/acme-client: https://acme-v01.api.letsencrypt.org/acme/new-authz: bad HTTP: 429
Jun 2 19:35:09 kernel: /usr/sbin/acme-client: transfer buffer: [{ “type”: “urn:acme:error:rateLimited”, “detail”: “Error creating new authz :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 }] (189 bytes)
Jun 2 19:40:01 rc_service: service 3258:notify_rc restart_letsencrypt
Jun 2 19:40:09 kernel: /usr/sbin/acme-client: https://acme-v01.api.letsencrypt.org/acme/new-authz: bad HTTP: 429
Jun 2 19:40:09 kernel: /usr/sbin/acme-client: transfer buffer: [{ “type”: “urn:acme:error:rateLimited”, “detail”: “Error creating new authz :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 }] (189 bytes)
Jun 2 19:45:01 rc_service: service 3707:notify_rc restart_letsencrypt
Jun 2 19:45:07 kernel: /usr/sbin/acme-client: https://acme-v01.api.letsencrypt.org/acme/new-authz: bad HTTP: 429
_Jun 2 19:45:07 kernel: /usr/sbin/acme-client: transfer buffer: [{ “type”: “urn:acme:error:rateLimited”, “detail”: “Error creating new authz :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/”, “status”: 429 }] (189 bytes)
Several times I changed the beginning of the domain: xxx.asuscomm.com unfortunately no changes
Please, maybe someone already had that?
Regards…
Is your device reachable from outside your network on port 80?
Maybe check your domain on https://letsdebug.net/ and see if it comes up with anything useful.
Thanks for the answer … I do not know myself … actually checking that port 80 is unavailable, but the router in the logs shows that it connects to ASUS on port 80 … I do not know how to redirect port 80 from outside on a port that is theoretically open …
Regards
If you are on a residential ISP, port 80 may be blocked.
This would not affect you personally since you are inside your own network, but it would affect others.
Otherwise,
- double check the port forwarding rules on your router.
- double check that the domain has your current IP address. I notice from the previous challenge URL that your IP address has since changed.
