'ascii' codec can't decode byte 0xe6 in position 1: ordinal not in range(128). Skipping
[root@host ~]# sudo ./certbot-auto renew --dry-run
Processing /etc/letsencrypt/renewal/www.tingtashuo.cn.conf
http-01 challenge for www.tingtashuo.cn
Attempting to renew cert (www.tingtashuo.cn) from /etc/letsencrypt/renewal/www.tingtashuo.cn.conf produced an unexpected error: ‘ascii’ codec can’t decode byte 0xe6 in position 1: ordinal not in range(128). Skipping.
/etc/letsencrypt/live/www.tingtashuo.cn/fullchain.pem (failure)
The problem has been solved。
Delete all Chinese comments(include nginx.conf)
Hi @xiaoyuhao0716,
Nonetheless, you have identified a bug in Certbot because it should not be necessary for users to delete foreign-language comments. So, I’ve just filed an issue about this in our bug tracker.
Sorry for the inconvenience!
I tried to add the following code to parse.py, and it works.
import sys
reload(sys)
sys.setdefaultencoding('utf8')
