I’m having trouble with configuring my server to use https for both the root site and the www. version.
My Apache virtual hosts configuration looks like this:
<VirtualHost *:80>
ServerName www.example.com
ServerAlias example.com
DocumentRoot /var/www/www.example.com/public_html
</VirtualHost>
When I run the command it works, but:
./letsencrypt-auto --apache -d www.example.com -d example.com
Going directly to example.com causes a certificate error to appear (because the certificate is for www.example.com not example.com). Is there an easy way to do a secure redirect?
– EDIT –
For a site like this:
<VirtualHost *:80>
</VirtualHost>
You should do this:
not this:
./letsencrypt-auto --apache -d example.com
My bad, the error it shows is this:
This webpage has a redirect loop
ERR_TOO_MANY_REDIRECTS
The generated configuration file looks like this:
<IfModule mod_ssl.c>
<VirtualHost *:443>
SSLCertificateFile /etc/letsencrypt/live/www.example.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.example.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/www.example.com/chain.pem
</VirtualHost>
</IfModule>
As a side note, I've now used up all of my allotted certificate generations with testing...
There were too many requests of a given type :: Error creating new cert :: Too many certificates already issued for: example.com
I think I’ve finally figured out the solution to my problem! I originally ran the commands separately, not both at the same time.
<VirtualHost *:80>
</VirtualHost>
You should do this:
not this:
