Apache plugin is installed, is not installed
My domain is: bitstorm.org
sudo certbot certonly --apache --cert-name bitstorm -d bitstorm.org -d www.bitstorm.org
http-01 challenge for bitstorm.org
http-01 challenge for www.bitstorm.org
Challenge failed for domain bitstorm.org
Challenge failed for domain www.bitstorm.org
Server version: Apache/2.4.41 (Ubuntu)
Ubuntu 20.04.1 LTS
certbot 0.40.0
Installed apache plugin: python3-certbot-apache
Strange thing is, sudo certbot plugins returns apache plugin, but logfile says:
2020-10-04 11:42:56,728:INFO:certbot.renewal:Cert is due for renewal, auto-renewing...
2020-10-04 11:42:56,728:INFO:certbot.renewal:Non-interactive renewal: random delay of 459.2428117522985 seconds
2020-10-04 11:50:36,068:DEBUG:certbot.plugins.selection:Requested authenticator apache and installer apache
2020-10-04 11:50:36,068:DEBUG:certbot.plugins.selection:No candidate plugin
2020-10-04 11:50:36,068:DEBUG:certbot.plugins.selection:Selected authenticator None and installer None
2020-10-04 11:50:36,068:INFO:certbot.main:Could not choose appropriate plugin: The requested apache plugin does not appear to be installed
2020-10-04 11:50:36,069:WARNING:certbot.renewal:Attempting to renew cert (bitstorm) from /etc/letsencrypt/renewal/bitstorm.conf produced an unexpected error: The requested apache plugin does not appear to be installed. Skipping.
Hi @edwinm
if you have that error, Certbot doesn't understand your config.
What says
apachectl -S
Are there duplicated combinations port 80 + domain names?
It looks like this is a second issue, besides the first issue @JuergenAuer already addressed. The latter part of your post looks like it was started from a cronjob? Because it says "Non-interactive renewal". Could it be that certbot runs in a different environment?
Please show this file:
EDIT: Without knowing anything else, I would say you might benefit from replacing your current certbot with the latest version from snaps.
[replace here means to properly apt remove the existing certbot and components first]
Osiris: Both commands are run from the same command line.
Output of apachectl -S:
VirtualHost configuration:
192.168.0.23:443       is a NameVirtualHost
         port 443 namevhost bitstorm.org (/etc/apache2/sites-enabled/www.bitstorm.org-le-ssl.conf:4)
                 alias www.bitstorm.org
*:80                   bitstorm.org (/etc/apache2/sites-enabled/www.bitstorm.org.conf:1)
AH00515: WARNING: MaxRequestWorkers of 500 would require 20 servers and would exceed ServerLimit of 16, decreasing to 400. To increase, please see the ServerLimit directive.
ServerRoot: "/etc/apache2"
Mutex fcgid-proctbl: using_defaults
Mutex proxy: using_defaults
Mutex fcgid-pipe: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33 not_used
Group: name="www-data" id=33 not_used
cat /etc/letsencrypt/renewal/bitstorm.conf
cert = /etc/letsencrypt/live/bitstorm/cert.pem
privkey = /etc/letsencrypt/live/bitstorm/privkey.pem
chain = /etc/letsencrypt/live/bitstorm/chain.pem
fullchain = /etc/letsencrypt/live/bitstorm/fullchain.pem
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/bitstorm
# Options and defaults used in the renewal process
[renewalparams]
authenticator = apache
account = 5d24ff87814951619b6cb820371a11d5
installer = apache
What was the exact command for the latter part of your post then?
There
you see the problem.
The port 80 vHost doesn't have the www domain name. So there is no matching vHost of your command.
* apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache.entrypoint:ENTRYPOINT
* standalone
Description: Spin up a temporary webserver
Entry point: standalone = certbot.plugins.standalone:Authenticator
* webroot
Description: Place files in webroot directory
Entry point: webroot = certbot.plugins.webroot:Authenticator
The output of /var/log/letsencrypt/letsencrypt.log is the same as mentioned earlier. So the same command that prints the existence of the apache plugin writes a log about missing the apache plugin.
I'm doubting that very much. Are you checking the correct log file? Because the log file in your first post showed a renewal attempt. That would never be in a certbot plugins command.
This is plain copy and paste of my terminal:
[edwin:~]$ sudo certbot plugins
* apache
* standalone
* webroot
[edwin:~]$ sudo ls -l /var/log/letsencrypt/letsencrypt.log
-rw-r--r-- 1 root root 576517 Oct  6 20:54 /var/log/letsencrypt/letsencrypt.log
[edwin:~]$ date
Tue 06 Oct 2020 08:54:17 PM UTC
[edwin:~]$ sudo head /var/log/letsencrypt/letsencrypt.log
2020-10-04 11:42:56,705:DEBUG:certbot.main:certbot version: 0.40.0
2020-10-04 11:42:56,705:DEBUG:certbot.main:Arguments: ['-q']
2020-10-04 11:42:56,705:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-10-04 11:42:56,713:DEBUG:certbot.log:Root logging level set at 30
2020-10-04 11:42:56,713:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-10-04 11:42:56,720:DEBUG:certbot.plugins.selection:Requested authenticator <certbot.cli._Default object at 0x7f4f5ddf66d0> and installer <certbot.cli._Default object at 0x7f4f5ddf66d0>
2020-10-04 11:42:56,728:DEBUG:certbot.storage:Should renew, less than 30 days before certificate expiry 2020-10-19 15:22:24 UTC.
See the date? That's 2 days ago.
Oh, thanks, I looked over this! I'm not used to debug info to append to the logfile.
It does find the apache plugin.
2020-10-06 20:54:07,969:DEBUG:certbot.main:certbot version: 0.40.0
2020-10-06 20:54:07,970:DEBUG:certbot.main:Arguments: []
2020-10-06 20:54:07,970:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2020-10-06 20:54:07,983:DEBUG:certbot.log:Root logging level set at 20
2020-10-06 20:54:07,983:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2020-10-06 20:54:07,984:DEBUG:certbot.main:Expected interfaces: None
2020-10-06 20:54:07,984:DEBUG:certbot.main:Filtered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
@JuergenAuer I do have an ServerAlias www.bitstorm.org. I will investigate why it's not showing with apachectl -S.
And have you considered replacing your current certbot with the latest version from snaps ?
Here's an update.
I installed the snap version of certbot, but that didn't solve the issue.
Then I went over the rate limit and couldn't investigage further.
Then, 30 minutes later, I ran the command again and it suddenly worked!
I'm glad it is working again, but my confidence in the software has dropped a bit.
Thanks for your help.
You should really understand that part of the problem is more than likely in the Apache config.
[&2* readers: Get involved; Be heard. It starts with: if you read something you like, then like it :heart:]
