Apache on Debian Bullseye
www.miim.com
/usr/local/bin/certbot-auto --apache --apache-server-root /usr/local/apache2
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel): ****************@miim.com
agree in order to register with the ACME server at
https://acme-v02.api.letsencrypt.org/directory
(A)gree/©ancel: a
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: n
1: www.miim.com
2: therenderingplant.com
3: www.therenderingplant.com
blank to select all options shown (Enter ‘c’ to cancel): 1 3
http-01 challenge for www.miim.com
http-01 challenge for www.therenderingplant.com
File: /etc/apache2/le_http_01_challenge_pre.conf - Could not be found to be deleted
  • Certbot probably shut down unexpectedly
    File: /etc/apache2/le_http_01_challenge_post.conf - Could not be found to be deleted
    An unexpected error occurred:
    IOError: [Errno 2] No such file or directory: ‘/etc/apache2/le_http_01_challenge_pre.conf’
  • Your account credentials have been saved in your Certbot
    root:/usr/src/certbot> ls /etc/letsencrypt
    accounts cli.ini csr keys options-ssl-apache.conf renewal renewal-hooks
    root:/usr/src/certbot> ls /etc/apache2
    ls: cannot access ‘/etc/apache2’: No such file or directory
Apache 2.4.41, built from distribution – NOT the Debian auto-installed one
Debian linux Bullseye
n/a
no
certbot 0.40.1
Notes:
  1. The Debian apt installation of Certbot cannot be used because this system has an Apache built from distribution. Attempting to install the Debian apt version would destroy the existing web server and configuration.
  2. Despite having told Certbot that the Apache distribution is rooted at /usr/local/apache2/conf, it appears to be attempting to use config files located in what would be the Debian install config root, /etc/apache2.
Question: Before going forward with attempting to activate SSL, have I got a usable configuration or not; and how do I confirm that the configuration is usable?
I tried reproducing this on Debian Bullseye and Apache httpd build from source with --prefix /usr/local/apache.
The cause of this appears to be a Debian platform default for --apache-challenge-location.
I was able to get past it and ultimately issue and install the certificate, by including that flag, along with others:
certbot-auto --apache \
--apache-ctl /usr/local/apache/bin/apachectl \
--apache-logs-root /usr/local/apache/logs/ \
--apache-server-root /usr/local/apache/conf/ \
--apache-challenge-location /etc/letsencrypt \
-d example.org
Thank you for your prompt and detailed reply. I am restoring the system to the last backup before I started attempted the Certbot install so that I will have a clean platform to begin again. I’ll update after I get that done and attempt the new install.
I am considerably further along, I think.
http-01 challenge for <domain1>.com
http-01 challenge for <domain2>.com
http-01 challenge for www.<domain1>.com
http-01 challenge for www.<domain2>.com
Created an SSL vhost at /usr/local/apache2/conf/miim-le-ssl.conf
Unsupported directory layout. You may try to enable mod socache_shmcb and try again.
 - Unable to install the certificate
   /etc/letsencrypt/live/www.miim.com/fullchain.pem
   /etc/letsencrypt/live/www.miim.com/privkey.pem
   Your cert will expire on 2020-03-04. To obtain a new or tweaked
   version of this certificate in the future, simply run certbot-auto
   again with the "certonly" option. To non-interactively renew *all*
   of your certificates, run "certbot-auto renew"
a) Why would enabling a caching module solve problems with the Apache directory structure?
b) The SSL vhost file was not actually created, but as it looks like I am very close, am I now at a point where I can enable the SSL module and create a vhost config file manually?
It's an optional dependency of mod_ssl. I believe Certbot wants it for SSLStaplingCache.
I got the same error as you - once I uncommented socache_shmcb in httpd.conf and re-ran Certbot, the new virtual SSL host was created.
Edit: You might be able to avoid it entirely with --no-staple-ocsp, but I haven't tested it.
With the command string you supplied above, I was able to get the necessary certificates and store them.
I am unable to connect to the server on port 443 even internally – connection times out and Apache logs nothing – but I believe this is due to misconfiguration in the default server and vhost configuration files, and that is certainly to be expected in this situation. I will chase that problem myself and see if I can discover the cause.
Many thanks for your assistance. The sparse documentation for some of the necessary command options made it unlikely I would ever have solved this issue without help.
