Apache is not starting after I deleted ssl certificate from certbot
My domain is: www.tomebox.in
I ran this command: sudo certbot delete
It produced this output: AH00526: Syntax error on line 20 of /etc/apache2/sites-enabled/000-default-le-ssl.conf: SSLCertificateFile: file '/etc/letsencrypt/live/tomebox.in/fullchain.pem' does not exist or is empty Action 'configtest' failed. The Apache error log may have more information
My web server is (include version): apache 2.4.29
The operating system my web server runs on is (include version): ubuntu 18.04.4
My hosting provider, if applicable, is: digitalocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
Please ask if any further details are needed, Any help is much appriciated.
Hi @ramadheer
if you do that
without removing the file from your Apache config, the result is expected.
  • Disable that vHost (or)
  • change the file names, so a standard self signed certificate is used.
Never delete certificates that are used.
PS: Why isn't there a backup you can use? Never delete files if you don't have a backup (Rule no 1 using computers).
Hi @JuergenAuer thanks for reaching out. I am new to the world of server administration and was not knowing the possible outcomes my actions may have.
It would be really helpful for me if you can suggest me how I can disable that Vhost or change the file names.
Use this command to disable it:
sudo a2dissite 000-default-le-ssl
this command is giving the error: ERROR: Site 000-default-le-ssl does not exist!
Show the output of this command:
ls -l /etc/apache2/sites-enabled/
total 4
-rw-rw-r-- 1 www-data www-data 693 Oct 3 09:26 000-default.conf
I don't understand how apache is saying there is a problem in a conf file when it doesn't exist. Did you remove it?
sudo apache2ctl configtest
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Syntax OK
Syntax OK
yes I think i removed the config file
So the initial problem has gone once you removed the file.
I don't know what you want to do now but your site is redirecting http to https and you have removed the cert and the conf so you should fix that redirection.
yeah got it, thanks for the help buddy! :slight_smile:
