Apache | Installing Problem 443
cc-sw.de
Installing Instructions
Enabled Apache rewrite module
Redirecting vhost in /etc/apache2/sites-available/000-default.conf to ssl vhost in /etc/apache2/sites-available/000-d efault-le-ssl.conf
Error while running apache2ctl graceful.
httpd not running, trying to start
Action ā€˜graceful’ failed.
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:443
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:443
no listening sockets available, shutting down
AH00015: Unable to open logs
Rolling back to previous server configuration…
Encountered exception during recovery
File ā€œ/usr/lib/python2.7/dist-packages/certbot/error_handler.pyā€, line 99, in _call_registered
self.funcs-1
File ā€œ/usr/lib/python2.7/dist-packages/certbot/client.pyā€, line 495, in _rollback_and_restart
self.installer.restart()
File ā€œ/usr/lib/python2.7/dist-packages/certbot_apache/configurator.pyā€, line 1658, in restart
self._reload()
File ā€œ/usr/lib/python2.7/dist-packages/certbot_apache/configurator.pyā€, line 1669, in _reload
raise errors.MisconfigurationError(str(err))
MisconfigurationError: Error while running apache2ctl graceful.
  • An error occurred and we failed to restore your config and restart
    your server. Please submit a bug report to
    https://github.com/letsencrypt/letsencrypt
    Apache2
    Debian Jessie
no
The Problem that I have that nothing works anymore! Please Help!
Can you show us the command you entered?
Also, please check if your apache server is able to restart
Thank you
Command:
$ sudo certbot --authenticator webroot --installer apache
and or:
$ sudo certbot certonly --authenticator standalone --pre-hook ā€œapachectl -k stopā€ --post-hook ā€œapachectl -k startā€
Apache I have restarted. Not working
Okay so I have repaired all!
Can someone help me with this Problem? The Port 443
What I need to do?
So what error or problem are you having now?
You seem to have successfully obtained a certificate; I guess it just failed to install into Apache, because Apache apparently couldn’t bind to port 443. Do you have something else besides Apache listening on port 443?
sudo lsof -i :443 | grep LISTEN
(Aside: your site seems to be working over HTTPS because it’s behind Cloudflare’s CDN, so I assume you want to use Let’s Encrypt to encrypt the connection from Cloudflare back to your origin server. Of course you can also use Cloudflare’s Origin CA for that, but you would still have to figure out how to install the certificate to Apache anyway.)
Heey,
thanks for the answer!
I have dont it… It says
docker-pr 2682 root 4u IPv6 21209 0t0 TCP *:https (LISTEN)
But it“s right I have Cloudflare and it protects but I also want to have a ssl encript besides Domain/Cloudflare to server
You say I can do it if a think from Cloudflare…
I look at this but don“t know if it works
I have done it with Lets Encrypt…
But is this normal?
You can not use a certificate directly on an IP.
https://37.114.96.47/ will always fail that way.
Use the domain name instead:
https://www.cc-sw.de/
But since you are using CloudFlare, you are probably trying to force the https connection to your server to check if it is actually encrypted.
For that you will have to temporarily force the domain name (www.cc-sw.de) to resolve to your real IP.
You can do that in the HOSTS file.
In windows it can normally be found in the /windows/system32/drivers/etc folder.
In Linux, it is normally the /etc/hosts file.
Simply add an entry:
37.114.96.47 www.cc-sw.de
One final thought, since the site IP also can be resolved by the base domain name (cc-sw.de), you might want to include both names (cc-sw.de, www.cc-sw.de) in the certificate and in your vhost config block.
I have done it for www.cc-sw.de
Where I can add this for cc-sw.de?
I’m just curious… why not use both hostnames in one certificate…
Thank you
I have forgot to add it at installig process
Can I add them at later time?
You’d just need to issue a new certificate that includes both of the names you want it to cover - certificates are immutable once issued.
But then I must completly reinstall certbot…
Or what?
Can someone give me instructions
you don’t need to reinstall certbot each time to get a certificate.
Just run sudo certbot -d your domain -d your second hostname -d your third hostname (replace ā€œdomainā€ ā€œx hostnameā€ with your real hostname)
Thank you
certbot -d cc-sw.de -d www.cc-sw.de
requested (ref: /etc/letsencrypt/renewal/www.cc-sw.de.conf)
It contains these names: www.cc-sw.de
You requested these names for the new certificate: cc-sw.de, www.cc-sw.de.
certificate?
(E)xpand/©ancel: E
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
It is saying this!
Can you help?
Please see
This might result in needing to install a new version of Certbot after all, not because you're obtaining a new certificate, but because of the issue about ACME challenge implementations.
I would try adding:
--preferred-challenges http
or
--preferred-challenges tls-sni
This is not strictly true. Let's Encrypt does not currently issue certificates for IP addresses, but some CAs do, and it's a valid type of certificate.
For the purpose of this thread, it's close enough, but I think it's important that we be strictly correct here since people come to us for trusted advice. :slight_smile:
I thought that those IP certificates are now only under ā€œprivate CAā€ (public not trusted CAs)…
Isn’t issue trusted certificates from public trusted CA a violation of CA policies?
