Another renewed but still expired help request
My domain is:macjams.net
I ran this command: ```
sudo certbot -d $DOMAIN -d $WILDCARD --manual --preferred-challenges dns certonly
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/macjams.net.conf)
What would you like to do?
1: Keep the existing certificate for now
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
Amazon Lightsail LAMP7 instance
Welcome to Ubuntu 16.04.6 LTS (GNU/Linux 4.4.0-1109-aws x86_64)
I can SUDO
No
The version of my client is (e.g. output of `certbot --version` or `certbot-auto --version` if you're using Certbot):
certbot 0.31.0
I have followed the instructions at:
https://lightsail.aws.amazon.com/ls/docs/en_us/articles/amazon-lightsail-using-lets-encrypt-certificates-with-lamp#complete-the-prerequisites-lets-encrypt-lamp
In detail with this domain and several others but never had an issue.  I accidentally let the certificate expire on this domain and following these steps I'm still getting that the cert is expired when I go to the site.
Do you have a specific hostname that showed certificate invalid?
Currently your root domain has a valid certificate that’ll expire on Sep 30 12:42:32 2020 GMT.
If you successfully installed your certificate and reloaded your webserver, there might be cache to your local browser that still use the old certificate. In that case, you can try to use a online certificate checking tool such as ssllabs.com or use another browser to verify your certificate deployment.
Thank you
Hi Sevenzhu, my apologies… It looked like it just took a very long time to propagate.
I did clear brower caches and it suddenly started working.
One thing I did do differently was since the cert had expired completely I followed the final steps in that link I posted to copy the cert files into apache and restart.
That may have been what was needed. Not sure.
