Another failed authorization issue
Got the “Action required: Let’s Encrypt certificate renewals” email. So I did the steps described in How to stop using TLS-SNI-01 with Certbot
I never ran into an issue like that before.
My domain is: ok.fahmed.de
I ran this command: sudo certbot renew --dry-run
It produced this output: Processing /etc/letsencrypt/renewal/ok.fahmed.de.conf
http-01 challenge for ok.fahmed.de
Waiting for verification…
Attempting to renew cert (ok.fahmed.de) from /etc/letsencrypt/renewal/ok.fahmed.de.conf produced an unexpected error: Failed authorization procedure. ok.fahmed.de (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://ok.fahmed.de/.well-known/acme-challenge/G1Gf7h2lhuipYcRa7T6wKpgDvrR_caZnrFeIsjbV7uU: “\n\n403 Forbidden\n\n
Forbidden
\n<p”. Skipping.
/etc/letsencrypt/live/ok.fahmed.de/fullchain.pem (failure)
My web server is (include version): Apache2 2.4.25-3+deb9u6
The operating system my web server runs on is (include version): Debian 9
My hosting provider, if applicable, is: PixelX
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
Could you please show the output of the following?
apachectl -t -D DUMP_VHOSTS
output shows:
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1. Set the ‘ServerName’ directive globally to suppress this message
VirtualHost configuration:
*:443 ok.fahmed.de (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 127.0.1.1 (/etc/apache2/sites-enabled/000-default.conf:1)
Assuming that’s the full output, that’s looks OK.
Something is causing Certbot’s Apache authenticator to not combine well with how your port 80 virtual host is configured.
Would you be able to show the contents of /etc/apache2/sites-enabled/000-default.conf ?
first of all, thanks for your help!
content is:
<VirtualHost *:80>
# specifies what hostname must appear in the request’s Host: header to
#ServerName www.example.com
    DocumentRoot /var/www/html
    # error, crit, alert, emerg.
    # modules, e.g.
    #LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =ok.fahmed.de
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
<Directory /var/www/html/>
Options +FollowSymlinks
AllowOverride All
Is that the full file? Seems to have been cut off a little bit at the end.
Also how about this:
grep -Ri "Strict-Transport" /etc/apache2
Hi @wawawa
I see, you have already tested your domain via https://check-your-website.server-daten.de/?q=ok.fahmed.de
But your domain has a CNAME entry:
ok.fahmed.de C ahmed.spdns.de yes 1 0
A 87.172.167.104 yes
www.ok.fahmed.de Name Error yes 1 0
So ahmed.spdns.de is used. Loading this domain manual, there is a nextcloud login.
So this configuration and the webserver there is relevant to validate your domain name.
It is indeed the full file.
Command shows: /etc/apache2/apache2.conf:Header always set Strict-Transport-Security “max-age=15768000; includeSubDomains; preload”
PS: Sorry, I should read the complete output of your test:
If you use http-01 - validation, Certbot creates a file in /.well-known/acme-challenge, Letsencrypt checks this file.
Port 80 is open. But there is a redirect to your login page. Your login page doesn’t know something about this test file.
So remove the redirect if the path starts with /.well-known/acme-challenge.
hmm…
.htaccess already has an exceptional case for .well-known… :
RewriteCond %{REQUEST_URI} !^/.well-known/(acme-challenge|pki-validation)/.*
Then there must be an error. The tool sees a redirect:
So share the content your your .htaccess
I also upgraded before from 0.18 to 0.28
This is the content of my .htaccess file:
<IfModule mod_headers.c>
  <IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
   SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
   RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
   SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
  </IfModule>
  <IfModule mod_env.c>
# Add security and privacy related headers
Header set X-Content-Type-Options "nosniff"
Header set X-XSS-Protection "1; mode=block"
Header set X-Robots-Tag "none"
Header set X-Download-Options "noopen"
Header set X-Permitted-Cross-Domain-Policies "none"
Header set Referrer-Policy "no-referrer"
SetEnv modHeadersAvailable true
  </IfModule>
  # Add cache control for static resources
  <FilesMatch "\.(css|js|svg|gif)$">
Header set Cache-Control "max-age=15778463"
  </FilesMatch>
  # Let browsers cache WOFF files for a week
  <FilesMatch "\.woff2?$">
Header set Cache-Control "max-age=604800"
  </FilesMatch>
</IfModule>
<IfModule mod_php5.c>
  php_value upload_max_filesize 10G
  php_value post_max_size 10G
  php_value memory_limit 512M
  php_value mbstring.func_overload 0
  php_value always_populate_raw_post_data -1
  php_value default_charset 'UTF-8'
  php_value output_buffering 0
SetEnv htaccessWorking true
  </IfModule>
</IfModule>
<IfModule mod_php7.c>
  </IfModule>
</IfModule>
<IfModule mod_rewrite.c>
  RewriteEngine on
  RewriteCond %{HTTP_USER_AGENT}  DavClnt
  RewriteRule ^$         /remote.php/webdav/          [L,R=302]
  RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
  RewriteRule ^\.well-known/host-meta /public.php?service=host-meta [QSA,L]
  RewriteRule ^\.well-known/host-meta\.json /public.php?service=host-meta-json [QSA,L]
  RewriteRule ^\.well-known/webfinger /public.php?service=webfinger [QSA,L]
  RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
  RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
  RewriteRule ^remote/(.*) remote.php [QSA,L]
  RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
  RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/.*
  RewriteRule ^(?:\.|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
<IfModule mod_mime.c>
  AddType image/svg+xml svg svgz
  AddEncoding gzip svgz
</IfModule>
<IfModule mod_dir.c>
  DirectoryIndex index.php index.html
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
<IfModule pagespeed_module>
  ModPagespeed Off
</IfModule>
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 //
ErrorDocument 404 //
You have other RewriteRules with L at the end and no / at the beginning.
So use the same rule with your .well-known/acme-challenge directory.
But I don't see there a redirect to your login page. So this place may be wrong.
Perhaps that should read:
RewriteCond %{REQUEST_URI} !^/\.well-known/(acme-challenge|pki-validation)/(.*)
Is it possible that the directory ./well-known/acme-challenge was not created? I searched for it, but can’t find it.
I was able to renew the certificate. Mea culpa. I had a Geo-IP lock installed which prevented the challenge file from being accessed by the authority.
