Android browsers problem and chain issues on Tomact 8.x - Incomplete Certificate Chain
My domain is: retok.ddns.net
To renew the certificate I do the following:
1 - Renew Certificate
C:>java -jar acme_client.jar -a c:\Dados\WebServerCertificate\account.key -w c:\Dados\WebServerCertificate\ --command renew-certificate --csr c:\Dados\WebServerCertificate\retok.ddns.net.csr --cert-dir c:\Dados\WebServerCertificate\wellknown --log-dir c:\Dados\WebServerCertificate
{“status”:“ok”}
2 - Convert the openssl certificate to PKCS12
C:>c:\Programas\GnuWin32\bin\openssl.exe pkcs12 -export -in c:\Dados\WebServerCertificate\wellknown\cert.pem -inkey retok.ddns.net.key -out server.p12
Loading ‘screen’ into random state - done
Enter Export Password:
Verifying - Enter Export Password:
3 - Delete or rename the c:\Dados\WebServerCertificate\server.keystore
delete c:\Dados\WebServerCertificate\server.keystore
4 - Convert a PKCS12 to java keystore format
C:>keytool -importkeystore -deststorepass -destkeypass -destkeystore server.keystore -srckeystore server.p12 -srcstoretype PKCS12 -srcstorepass
Entry for alias 1 successfully imported.
Import command completed: 1 entries successfully imported, 0 entries failed or
cancelled
5 - Import fullchains to the certificate
C:>keytool -import -alias root -keystore server.keystore -trustcacerts -file c:\Dados\WebServerCertificate\wellknown\fullchain.pem
Enter keystore password:
Certificate already exists in keystore under alias <1>
Do you still want to add it? [no]: y
Certificate was added to keystore
6 - Import the chains to the certificate
C:>keytool -import -alias tomcat -keystore server.keystore -trustcacerts -file c:\Dados\WebServerCertificate\wellknown\chain.pem
7 - Rename the old .keystore
rename C:\WINDOWS\system32\config\systemprofile.keystore .keystore_2017_05_07
8 - Copy server.keystore as .keystore to system profile
copy c:\Dados\WebServerCertificate\server.keystore C:\WINDOWS\system32\config\systemprofile.keystore
9 - Restart Tomcat server
I already tested from several Androids and all returns the same error: CERT_AUTHORITY_INVALID (all my Android phones and tablets and I already tested with some friends of mine Androids equipments). I do not believe all the Androids are wrong configured! I believe the Android browsers do not recognise yet the Lets Encript as a valide certification authority. Do you have any idea when Android will recognise Lets Encript?
When I run browsers in Windows and Apple IOS machines everything seems to be working fine, only in Androids I receive this error.
In https://www.ssllabs.com says to my site “Chain Issues Incomplete”.
What is missing in my certificate? What I am doing wrong to have this problem with Android phones and ssllabs returns that error?
My operating system is (include version): Microsoft Windows XP - Home Edition - Version 2002 - Service Pack 2
My web server is (include version): Tomcat 8.0
My hosting provider, if applicable, is: Not applicable
Hi @arjava,
Use the fullchain.pem instead of cert.pem
c:\Programas\GnuWin32\bin\openssl.exe pkcs12 -export -in c:\Dados\WebServerCertificate\wellknown\fullchain.pem -inkey retok.ddns.net.key -out server.p12
There is no need to import again the fullchain.
As far as I know you shouldn't import the chain too.
Cheers,
sahsanu
Hi Sahsanu,
I implement your recomendations and averything works fine.
ssllabs site do not indicate any error anymore.
Android equipments do not indicate the certificate error anymore also.
Thank you very much,
Best regards
António Rodrigues
