My domain is: treva.maurice.net
I ran this command: sudo certbot --apache -d treva.maurice.net
It produced this output: An unexpected error occurred: StopIteration
CONTENT:
2019-01-04 18:45:08,582:DEBUG:certbot.error_handler:Calling registered functions
2019-01-04 18:45:08,583:DEBUG:certbot.reporter:Reporting to user: Unable to install the certificate
2019-01-04 18:45:08,583:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.28.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1340, in main
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 1101, in run
_install_cert(config, le_client, domains, new_lineage)
File “/usr/lib/python3/dist-packages/certbot/main.py”, line 735, in _install_cert
path_provider.cert_path, path_provider.chain_path, path_provider.fullchain_path)
File “/usr/lib/python3/dist-packages/certbot/client.py”, line 498, in deploy_certificate
fullchain_path=fullchain_path)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 334, in deploy_cert
vhosts = self.choose_vhosts(domain)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 358, in choose_vhosts
return [self.choose_vhost(domain, create_if_no_ssl)]
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 540, in choose_vhost
vhost = self.make_vhost_ssl(vhost)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 1115, in make_vhost_ssl
self._copy_create_ssl_vhost_skeleton(nonssl_vhost, ssl_fp)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 1259, in _copy_create_ssl_vhost_skeleton
ssl_vh_contents, sift = self._sift_rewrite_rules(orig_contents)
File “/usr/lib/python3/dist-packages/certbot_apache/configurator.py”, line 1331, in _sift_rewrite_rules
line = next(contents)
StopIteration
2019-01-04 18:45:08,584:ERROR:certbot.log:An unexpected error occurred:
My web server is (include version): Apache2
My hosting provider, if applicable, is: NA
