Adding certbot ssl certification to custom domain on surge
My domain is: hectorcoronado.codes
I ran this command: sudo certbot
No names were found in your configuration files. Please enter in your domain name(s) (comma and/or space separated) (Enter ‘c’ to cancel): hectorcoronado.codes
http-01 challenge for hectorcoronado.codes
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
My web server is (include version): either HAProxy or Apache (I’m using surge, and apparently it can use either/or, see https://surge.sh/help/securing-your-custom-domain-with-ssl#get-the-cert-signed)
The operating system my web server runs on is (include version): I don’t know
My hosting provider, if applicable, is: surge
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Note: surge doesn’t automatically support Let’sEncrypt (see https://twitter.com/surge_sh/status/676285277078351873?lang=en), but does so for beta users, which I’ve been added to their list. Any help would be greatly appreciated; I’ve next to no experience trying to debug these kind of issues :confused:
You’re probably going to have to do manual DNS verification:
certbot certonly --manual --preferred-challenges dns -d hectorcoronado.codes
and setup the requested TXT records in your Google Domains DNS control panel.
Then, you will have these files:
  1. /etc/letsencrypt/live/hectorcoronado.codes/privkey.pem
  2. /etc/letsencrypt/live/hectorcoronado.codes/fullchain.pem
Then you:
cat /etc/letsencrypt/live/hectorcoronado.codes/privkey.pem /etc/letsencrypt/live/hectorcoronado.codes/fullchain.pem > /root/surge.pem
surge ssl --pem /root/surge.pem --domain hectorcoronado.codes
Not very automated, but unless you ditch Google Domains as your DNS host, there’s no way really to improve the workflow.
(Edit: to clarify, you cannot use HTTP-01 validation in combination with surge, because they intercept the /.well-known/acme-challenge/ requests, presumably for their own integration. So you must use DNS validation.)
Bit late to reply, but thank you very much for this, @_az, sorted it out!
