Add --must-staple when renewing a certificate
My domain is: staging.pricingmonkey.com
certbot renew --cert-name staging.pricingmonkey.com --must-staple --force-renewal
It produced this output: n/a
My web server is (include version): n/a (certificate was obtained with certonly and uses a dns challenge)
The operating system my web server runs on is (include version): ubuntu 20.04
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
I have some existing certificates and I want to add the the OCSP Must Staple extension to them. I tried with the command above, and it completed with no errors: the certificate was renewed successfully, and must_staple = True was added to the renewal config. But when I checked the certificate afterwards (with openssl x509 -text), the certificate did not have the OCSP Must Staple flag. Interestingly, this worked fine when I tried the same with a staging certificate: after renewal the certificate had the flag as expected.
Thanks,
Max
Hi @maxfliri
checking your domain there is the OCSP Must staple.
With my browser (FireFox), via https://check-your-website.server-daten.de/?q=staging.pricingmonkey.com#certificates
via SSL Server Test (Powered by Qualys SSL Labs)
It's also clearly visible in the certificate itself with an OpenSSL output:
https://crt.sh/?id=4193993337
Well, this is embarrassing. You are right, but for some reason last night I could not see it, and I did check and recheck before opening this thread. Now I checked again, and tried again with another certificate, and yes everything works as expected. :weary:
Thank you so much for your time and help, it's much appreciated.
