About the problem of not being able to renew the certificate
When I was renewing the certificate, the network is unreachable message appeared. Is it because my IP is blocked? If so, what should I do? requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f2a3f344f60>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
This is my error code, using cerbot
My domain is:anki.szhtgroup.com
I ran this command: sudo certbot certonly --renew-by-default -d anki.szhtgroup.com --manual --preferred-challenges dns
An unexpected error occurred:
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 144, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network is unreachable
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 601, in urlopen
chunked=chunked)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 346, in _make_request
self._validate_conn(conn)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 852, in _validate_conn
conn.connect()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 298, in connect
conn = self._new_conn()
File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 153, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7f55b6263f60>: Failed to establish a new connection: [Errno 101] Network is unreachable
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 440, in send
timeout=timeout
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f55b6263f60>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
File "/usr/lib/python3/dist-packages/acme/client.py", line 1120, in _send_request
response = self.session.request(method, url, *args, **kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 520, in request
resp = self.send(prep, **send_kwargs)
File "/usr/lib/python3/dist-packages/requests/sessions.py", line 630, in send
r = adapter.send(request, **kwargs)
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f55b6263f60>: Failed to establish a new connection: [Errno 101] Network is unreachable',))
ValueError: Requesting acme-v02.api.letsencrypt.org/directory: Network is unreachable
It could be a temporary problem but check that your server is able to communicate with the Let's Encrypt API:
https://acme-v02.api.letsencrypt.org/
e.g. curl https://acme-v02.api.letsencrypt.org/directory
curl: (7) Failed to connect to acme-v02.api.letsencrypt.org port 443: Connection timed out
root@ankiupdate:/var/log/letsencrypt# curl https://acme-v02.api.letsencrypt.org/directory
I tried what it showed. Is it this result or a timeout? I don’t know if the IP address is blocked. Is there any other way to update the certificate?
That's a timeout, it's very unlikely that your IP would be blocked.
Try curl https://acme.zerossl.com/v2/DV90 (which is the directory for ZeroSSLs ACME CA).
If that doesn't work then your server probably just doesn't have outgoing TCP port 443 internet access or doesn't have a route via your internet service provider.
You've gotten a certificate for that hostname this morning: crt.sh | 13386714701. Did you already succeed?
Also:
Please do NOT use this option if it's not necessary. I believe one of the original Certbot developers has called it their biggest mistake. It usually only leads to hitting rate limits.
