Since I am a newbie, I don’t know if what I am going to ask is a stupid question.
My question is: where should I put the line of code below?
ssl_trusted_certificate /etc/letsencrypt/live/yourdomain/chain.pem;
Should it be in the /etc/letsencrypt/options-ssl-nginx.conf; or should I let it in the virtual host file?
If you’re using nginx, you shouldn’t need to use chain.pem at all. You’d use fullchain.pem as the certificate file.
rg305
May 11, 2018, 8:51pm
3
what version of nginx?
nginx -v
@rg305 I am using nginx 1.10.3
rg305
May 11, 2018, 9:07pm
5
OK then I’m in agreement with @danb35
@rg305 what about
ssl_stapling on;
ssl_stapling_verify on;
rg305
May 11, 2018, 9:28pm
7
If you are using OCSP, then yes, those commands should work.
It would be best to put it next to ssl_certificate and ssl_certificate_key. It keeps life simple, and different certificates can potentially have different chains (though they typically won't).
