403 after using letsencrypt
My domain is: vallabh.codes
I ran this command: sudo apachectl status
/usr/sbin/apachectl: 113: www-browser: not found
'www-browser -dump http://localhost:80/server-status' failed.
Maybe you need to install a package providing www-browser or you
need to adjust the APACHE_LYNX variable in /etc/apache2/envvars
My web server is (include version): apache2
The operating system my web server runs on is (include version): Ubuntu 20.04 LTS
My hosting provider, if applicable, is: Digitalocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.4.0
I have hosted a django project on a droplet on digital ocean. This is my first time hosting a project on a server.
I generated the certificate and it worked initially for few minutes. But now it shows 403 forbidden. Please help
Hi @vallabhtiwari, and welcome to the LE community forum :slight_smile:
Then the certificate should be good.
So, what happened with Apache after that time?
Can you revert the Apache configuration?
If not, can you uninstall and then reinstall it?
Hi @rg305 , thanks. I reinstalled all my configurations. Right now www.vallabh.codes is working but not vallabh.codes . Previously both worked for few minutes. I followed these instructions. Am I missing something in the ssl certificate generation?
Here SSL Server Test: www.vallabh.codes (Powered by Qualys SSL Labs) the certificate only has www.vallabh.codes in it: Alternative names www.vallabh.codes; therefor would have issues with just vallabh.codes as shown here SSL Server Test: vallabh.codes (Powered by Qualys SSL Labs).
Not likely.
Let's confirm that with:
certbot certificates
Thank you!! Also how can I confirm that http traffic will be redirected to https
It did not ask during the setup. But in youtube tutorials, old I guess it used to ask. Like a status command or something
I use this online tool as one means to check redirect https://www.redirect-checker.org/
It seems that http://vallabh.codes does NOT redirect, but http://www.vallabh.codes does redirect to https://www.vallabh.codes/
Got it!! Also I can't understand why vallabh.codes is not working. I have added the DNS records in my DigitalOcean networking section.
Is something wrong here? Thanks
Also the Certificate being served is only for www.vallabh.codes
vallabh.codes - https://decoder.link/sslchecker/vallabh.codes/443
www.vallabh.codes - https://decoder.link/sslchecker/www.vallabh.codes/443
In your web server configuration you need sections for each vallabh.codes and www.vallabh.codes
Here details on Apache can be found in documentation and forums:
Kindly wait to see if there are more knowledgeable Let's Encrypt community volunteers willing to assist.
Hi @Bruce5051 thanks !! This helped me
Do check my portfolio !!:grin:
@vallabhtiwari It looks like your HTTP to HTTPS redirects are now working for both of your domain names. So, the only thing that is not working is if someone tries HTTPS for vallabh.codes. This will fail because your certificate only has your www.vallabh.codes domain name in it and it must have both of these names.
You should redo your original cert request including both names
Here's what is not working right now
curl -I https://vallabh.codes
curl: (60) SSL: no alternative certificate subject name matches target host name 'vallabh.codes'
More details here: https://curl.se/docs/sslcerts.html
But if they start with HTTP it works fine (b/c it redirects to www)
curl -IL http://vallabh.codes
Server: Apache/2.4.41 (Ubuntu)
HTTP/1.1 200 OK
Yes I am looking into that right now. Help would be appreciated
What command did you use to get your cert?
sudo certbot --apache
This is conf for port 80
<VirtualHost *:80>
    ServerName vallabh.codes
    Redirect permanent / http://www.vallabh.codes/
</VirtualHost>
<VirtualHost *:80>
	# specifies what hostname must appear in the request's Host: header to
	ServerName www.vallabh.codes
	DocumentRoot /var/www/html
	# error, crit, alert, emerg.
	# modules, e.g.
	#LogLevel info ssl:warn
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.vallabh.codes
</VirtualHost>
And for 443
<IfModule mod_ssl.c>
<VirtualHost *:443>
	# modules, e.g.
	Alias /static /path
	<Directory /path>
		Require all granted
	</Directory>
	Alias /media /path
	<Directory /path>
		Require all granted
	</Directory>
	<Directory /path>
		<Files wsgi.py>
			Require all granted
		</Files>
	</Directory>
	WSGIDaemonProcess proj python-home=/path python-path=/path/proj
	WSGIProcessGroup proj
	WSGIScriptAlias / /path/wsgi.py
SSLCertificateFile /path.pem
SSLCertificateKeyFile /path.pem
Include /path/options-ssl-apache.conf
</VirtualHost>
</IfModule>
Hi @MikeMcQ I think everything is good now. Could you please check again?
This Apache redirection of both http to https and non www to www - Stack Overflow helped.
The problem I described in post #13 still exists. You still need to get a cert with both domain names in it.
But, from your latest info I see you are using WSGI along with the certbot --apache plug-in. That won't work well. You should use the --webroot / -w options instead.
Please show output of this and we can provide format for this new command:
Found the following certs:
  Certificate Name: www.vallabh.codes
    Serial Number: 3fa389190a66470c21b4a63eef75798a4bc
    Key Type: ECDSA
    Domains: www.vallabh.codes
    Expiry Date: 2023-06-25 11:16:59+00:00 (VALID: 88 days)
    Certificate Path: /etc/letsencrypt/live/www.vallabh.codes/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/www.vallabh.codes/privkey.pem
How can I generate for vallabh.codes ? Before generating the certificate I had only one config file in which I had mentioned my ServerName www.vallabh.codes. The certbot created one for port 443.
