Hello,
I'm trying to add 2-way SSL authentication on my Express REST API and fixed client. I followed this in order to generate the appropriate certificates and keys for server-side and client-side and this is my code on the server-side:
const https = require('https')
const express = require('express');
const app = express();
const port = 3000;
app.use(express.json());
app.use(bodyParser.urlencoded({ extended: false }));
app.use(morgan('combined'));
var helmet = require('helmet')
app.use(helmet())
app.get('/endpoint', async function(req, res, next) {
res.json({ message: 'Connection has been established successfully.' })
const sslServer = https.createServer({
key: fs.readFileSync(path.join(__dirname, 'cert', 'server-key.pem')),
cert: fs.readFileSync(path.join(__dirname, 'cert', 'server-crt.pem')),
ca: fs.readFileSync(path.join(__dirname,'cert', 'ca-crt.pem')),
requestCert: true,
rejectUnauthorized: true
}, app);
sslServer.listen(port, () => console.log(`Example app listening on port ${port}!`));
And on the client side:
const httpsAgent = new https.Agent({
key: fs.readFileSync(path.join(__dirname,'..','..','..','client1-key.pem')),
cert: fs.readFileSync(path.join(__dirname,'..','..','..','client1-crt.pem')),
ca: fs.readFileSync(path.join(__dirname,'..','..','..','ca-crt.pem')),
passphrase: "password",
rejectUnauthorized:true,
requestCert:true
axios.post('https://IP:PORT/endpoint',{
data: {
data1: data1,
data2: data2,
httpsAgent: httpsAgent
When I do this, I get the following:
Error: write EPROTO 140333960492168:error:10000410:SSL routines:OPENSSL_internal:SSLV3_ALERT_HANDSHAKE_FAILURE:../../third_party/boringssl/src/ssl/tls_record.cc:592:SSL alert number 40
at WriteWrap.onWriteComplete [as oncomplete] (internal/stream_base_commons.js:87:16)
I verified all my certificates and keys using (both the following send an 'okay' response):
openssl verify -CAfile ca-crt.pem server-crt.pem
openssl verify -CAfile ca-crt.pem client1-crt.pem
My question is, what is the significance and specifications of the CA Common Names for the certificate authority (ca-crt.pem), server certificate (server-csr.pem,) and client certificate (client1-csr.pem)? I added random Common Names for my certificate authority and client certificate, but for my server certificate it is the IP address of my server (without any protocol specification/port etc. just xxx.xxx.xx.xxx).
Furthermore, is there anything wrong with my code on the client or server-side that might get this handshake failure response?
Thanks very much for your help!
