2 domains one path using ServerAlias
My domain is: ein.world
I ran this command: nothing yet
It produced this output:n/a
My web server is (include version): Debian Apache 2
Yes
No
certbot 0.31.0
Hi, I set up my site like so:
2 <VirtualHost *:443>
3 ServerAdmin webmaster@eingame.cc
4 ServerName eingame.cc
5 ServerAlias www.eingame.cc
6 ServerAlias ein.world
7 ServerAlias www.ein.world
8
9 # Indexes + Directory Root.
10 DocumentRoot /home/eingame/public_html
11 DirectoryIndex index.php
12
13 <Directory /home/eingame/public_html>
14 Options Indexes FollowSymLinks
15 AllowOverride All
16 Require all granted
17
and
31 Include /etc/letsencrypt/options-ssl-apache.conf
32 SSLCertificateFile /etc/letsencrypt/live/eingame.cc/fullchain.pem
33 SSLCertificateKeyFile /etc/letsencrypt/live/eingame.cc/privkey.pem
But how do I get a ssl cert for ein.world since it is already set up as eingame.cc?
Your certificate can cover up to 100 subject alternative names (SAN), this means one cert file can cover up to 100 domains or subdomains (or it can even include multiple wildcards etc). To get a cert for multiple domains you would run certbot with the list of domains your site is known by.
certbot --apache -d ein.world
But you should also consider adding the "www" to that command:
certbot --apache -d ein.world -d www.ein.world
That said, you should be informed that LE prefers IPv6 (over IPv4) when present.
And, in this case, it is present:
Addresses: 2600:3c00::f03c:91ff:feb0:1b5b
           198.58.105.195
But IPv6 fails to reach the site (as IPv4 does):
curl -6I ein.world
HTTP/1.1 403 Forbidden
curl -4I ein.world
HTTP/1.1 200 OK
I tried doing this, and it works for http://ein.world but now my https://eingame.cc doesn't have a valid certificate.
How do I get both https://ein.world AND https://eingame.cc at the same time?
Keep in mind my apache file looks like this:
20:48 /etc/apache2/sites-enabled (master)$ cat eingame.cc-le-ssl.conf
ServerAdmin webmaster@eingame.cc ServerName eingame.cc ServerAlias www.eingame.cc ServerAlias ein.world ServerAlias www.ein.world
            AllowOverride All
            Require all granted
    </Directory>
    <IfModule mod_php5.c>
            AddType application/x-httpd-php .php
            php_flag magic_quotes_gpc Off
            php_flag track_vars On
            php_flag register_globals Off
            php_value include_path .
    </IfModule>
    # Logfiles
    ErrorLog  /home/eingame/logs/error.log
    CustomLog /home/eingame/logs/access.log combined
SSLCertificateFile /etc/letsencrypt/live/ein.world/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/ein.world/privkey.pem
<VirtualHost *:80>
            AllowOverride All
            Require all granted
    </Directory>
    </IfModule>
    # Logfiles
RewriteEngine on
Some rewrite rules in this file were disabled on your HTTPS site,
because they have the potential to create redirection loops.
RewriteCond %{SERVER_NAME} =eingame.cc [OR]
RewriteCond %{SERVER_NAME} =www.eingame.cc
That's another question [which you should have asked up front].
To that end, are there any more sites you want to also get a cert for?
In the meantime, if you want them on the same cert, add the sites to the list of names on the request command:
certbot --apache -d site.1 -d site.2 -d site.3 -d ...
But that doesn't seem like the right way to go; as the sites are not in the same vhost.
So, I would, get them separately:
certbot --apache -d site.1 -d www.site.1
certbot --apache -d site.2 -d www.site.2
certbot --apache -d site.3 -d www.site.3
